Results 1 to 25 of 25
    Active Member JimFoy's Avatar
    Aug 2012
    Farmersville TX
    Default Exactly what does "Eco Mode" do?
    Exactly what does "Eco Mode" do? I know the nanny shows when it thinks I should shift, but is that all there is too it? It seems to me that I detect a change in the engine when I go into Eco Mode -- a slight reduction in speed or in power. Does the fuel mixture change? Or is the shifting suggestion all there is to it?
    Jun 2010
    Las Vegas
    Here is a link to BRP press release info about the new motor. It wouldn't let me copy and paste the part about Eco Mode. http://can-am.brp.com/spyder/shoppin...spyder-rt.html It didn't say that the mode does anything but let you know when to shift.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member garb55's Avatar
    Coolidge Arizona
    I was reading somewhere yesterday but can not find it now
    ECO mode also limits throttle movement
    so you are getting 10% less throttle movement than you would without ECO mode
    Don
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    Default eco..!!
    you are really not saving enough to make it worth while...I would use it as a training tool limiting the learner from getting to wild...
    ​2012 RS sm5
    While I would really like to like it; it seems to just not quite perform up to expectations...
    More importantly; I takes the operator's concentration off of the roadway!
    Nice idea...
    Lousy execution...
    Very Active Member den1953's Avatar
    Sep 2013
    Fostoria, Ohio
    Default I tend to agree
    Anything that takes your attention away from the road is not good. I see enough of this already with car (cage) drivers using cell phones and smart phones. I can imagine GPS as being a distraction as well. The use of phones while driving around here is like a rampant epidemic with something like maybe 1 in 4 drivers. I've even seen semi truck drivers using them and that is really scary!! From what I've been reading on this forum the ECO Mode is practically worthless and not helping gas mileage all that much.
    If that little green arrow, was flashing on a heads-up display; it'd sure make a lot of difference in my opinion about it.
    A nice, big Green arrow in the middle of the windshield, would be much easeir to see in your peripheral vision.
    But then again; what would THAT cost???
    Very Active Member Wiredux's Avatar
    Aug 2012
    Jacksonville, NC
    I think it is a great concept as it does limit the throttle response. You don't have to keep your eyes pealed to your dash so you know when to shift. The green arrow is ONLY a suggestion not a requirement. How many people stare at their RPM's on a 998 to make sure they are at the right RPMs before they shift? You keep your eye on it until you understand and remember when to shift.
    Invalid Emails
    Jul 2010
    Central Connecticut
    Nice idea...
    Lousy execution...
    I've tried it on a couple of rides and it was very distracting. Now that I have an idea of the "optimal" shift points for gas savings, I'm going back to "normal" mode.
    Also tried it but don't like it. Too distracting. I can hear the sweet spot in the shift point--2500 - 3000 rpm. Don't need no steenkin Eco Mode.
    Would rather they did not have it and wish they would have kept the electronic frunk release.
    Active Member CentralCoastCA's Avatar
    Aug 2012
    Santa Barbara County, CA
    If you need to pass especially on a 2 lane road, be sure your Eco mode is off. Otherwise you won't be moving very fast
    Invalid Emails
    Aug 2010
    ohio
    I had an 08 Hayabusa that had 3 modes for driving. It changed the engine map/throttle response. Mode 1 was go fast, very, very fast. Mode 2 reduced the power and throttle response for "in town" driving. Mode 3 was for rain. Even snapping the throttle in mode 3 would't break the rear tire loose, so it was very nice when I got stuck out in the rain. Maybe the ECO mode would be more usefull on wet roads. The Hayabusa didn't have traction control and ABS brakes to help the wet stuff.
    Sep 2009
    Chelmsford, MA
    Default Helpful early on
    I had an RS and a 990 RT before I picked up the 2014 1330. Today I went on a 100 mile ride and used the eco mode. It was a good way to learn what gear BRP thinks I ought to be in. I normally run the RPMs higher before shifting than the green arrow suggests. I was good guidance for the day and now I know you can run this thing like a cruiser, shift at 2500 or so, it can lug to 2000 or so as well.
    It's a really relaxing way to putt along, not something I found true with the 990 motor. I didn't mind revving it and recall riding all day along the Colorado front range at about 6000 RPM- it was as smooth as a turbine and felt like it could go forever. The 1330 may be able to do that too- we shall see after break in.
    I did find the eco green upshift light a bit hard to see. I wasn't depending on it so it was no big deal. Overall it's not a bad thing as long as they didn't spend big bucks on it.
    The 1330 IS fun to just run along at a nice, low rpm level; letting the torque output handle the chores!
    Registered Users 3 Wheel Addict's Avatar
    Sep 2013
    Southwest Ohio
    My wifes new Honda CR-V has a green ECO button and she calls it "The driving sucks button"....
    Sold my 14 RTS went back to 2 wheels.
    2014 Kawasaki Vaquero SE
    Everybody hates how they need to drive, in order to save fuel...
    ...until it's time to pay the gas bill!
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    Default eco mode under rated
    Quote Originally Posted by JimFoy View Post
    When I bought my 2014 RT-S dealer didn't even mention "eco mode" I believe it is an alternative "map" for engine. In my experience with the semi auto, this detuning allows the smoothest possible shifts, almost seamless. This "lack of hit" for loss of a better term, is really only felt below 4 thousand RPM. and since I don't really wind it out in the first two gears anyway, It kind of adds a peaceful quality . I never even tried eco mode the first 3 thousand miles I went, but now... I like it. I totally ignore the :shift light. Like almost everything else in the goofy display, it's too small to get my notice.
    Related item, everyone makes so much noise about mpg. Everyone always seem to ask about that. IT'S A SPORTING MACHINE !
    If something like that is a big concern, well..... you see where I'm going. Enjoy the ride.
    Active Member Texas's Avatar
    Oct 2013
    Austin, TX
    I haven't been on the forum for a while; too busy out riding my RT-S. However, I saw the ECO thread and thought that since that is the only mode I use, I better weigh in. When I first started using it, I was slightly distracted by watching the screen. However, that didn't last long, because I learned to anticipate shift points based on feeling/hearing the RPM. Sometimes I glance down when shifting into 5th and 6th gears to know the exact moment when I can shift into those gears (32 mph going into 5th gear, and 38 mph going into 6th gear). Unlike others have mentioned, ECO does have a payoff. I get well above 40 mpg on every tank. Some of the other savings that is also often overlooked is longer tire wear and less wear and tear on the motor.
    I've ridden motorcycles for almost 30 years, but since owning the new RT-S, I've given them up. I just enjoy the RT-S way too much to justify keeping the bikes that I had (BMW K1600GTL & Triumph Tiger Explorer). Getting 42-45 mpg on my RT-S is icing on the cake. If I wanted to drive fast, I would have bought a Hayabusa.
    -Texas
    May 2014
    Courtenay,BC,Canada
    Default eco mode
    Quote Originally Posted by Texas View Post
    Experimented on I90 from Maine to Seattle with the eco mode. On cruise at staedy throtttle settings a gained 4% in fuel mileage using ECO mode. Before, around town I was getting 10% better fuel mileage when not in eco mode.Don't use Eco unless you are travelling with a steady throttle setting.Most of the time the Eco mode mutes the throttle response so much that it takes away from the fun of riding.
    Very Active Member Orange Spyder Man's Avatar
    Sep 2014
    3rd ROCK FROM THE SUN !
    my dealer did not mention the Eco mode when my bike was picked up...if I remember correctly I have to press the Eco mode & depress the brake to start my RT spyder..
    I have to ask ... pressing the Eco mode again turns it off ??
    Sep 2014
    USA
    Quote Originally Posted by Orange Spyder Man View Post
    Just hold the eco mode button in a few seconds to turn it on and off..
    Danbury Connecticut
    Here is what I found out trying the ECO mode on my 2014 RT-S SM6.
    The green arrow seems to pop up when you get past 3,000 rpm (or thereabouts).
    Manual ECO mode equivalent: Keep the RPM as low as possible all the time.
    I found it essentially worthless, and after experimenting with it for a weekend, I turned it off.
    The arrow is too distracting.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    I rode a 2014 RT limited for the weekend . I used the ECO MODE for the whole weekend . I was finding that I was constantly shifting and the RPM range was about 2200 to 2700RPM. I rode the spyder two up and conservatively not mashing the gas and brakes and I only got a little better fuel economy than the rest of the spyders not using ECO MODE. We rode a total of 1500 miles with a mix of highway and paved back road riding. JMHO
    I'm a pretty conservative rider, and I found no fuel economy advantage in using the ECO Mode...
    And trying to find the Green Light, was taking my eyes off of the road...
