Results 1 to 8 of 8
Thread: front tires
    Active Member godfather's Avatar
    cookeville tn
    Default front tires
    22,000 miles time to replace front tires, what are some of you using, and where did you find them
    thanks for help
    Jun 2010
    Las Vegas
    That is pretty much average for the fronts. I have always used the OEM Kendas on the front since they get pretty good mileage and there aren't many other options.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Choices choices..!!
    I have 20,000 so far and a ways to go so sticking with the stock tires. Many are going to car tires and there seem to be a large selection. Stick with the same size. I'll say no more folks get upset..Arachnid from Vee Rubber are a new spyder tire...happy hunting..!!
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    That seems like pretty good mileage off a set of fronts...
    Very Active Member mrfats's Avatar
    Jul 2011
    Morgantown, WV
    If you got 22,000 miles on them, I see no reason to change...
    I have also got good mileage out of the OEM front tires. 20-23K on all sets so far.
    Recently replaced fronts on the 2011 at 13,000 miles. One tire was showing wear on the edge due to misalignment. Will see how the new set works.
    Using OEM Kenda's again.
    cookeville tn
    Default Tires
    Thanks went with vee rubber, Dealer wanted $180 plus 60 to mount, vee is $144 free shipping
    Apr 2011
    GREENVILLE, SC
    Default TIRES
    SPYDER TIRES
    For front tires:
    MINE: Kumho Solus KH16 185/65-14 165/65R14 BARUM POLARIS 2
    165/65R14 KLEBER KRISALP 3
    165/65R14 UNIROYAL MS PLUS 5
    165/65R14 SEMPERIT WINTER-GRIP
    165/65R14 PIRELLI W190 SNOWCONTROL
    165/65R14 GOODYEAR ULTRAGRIP 7
    165/65R14 DUNLOP SP WINTER SPORT M3
    165/65R14 CONTINENTAL TS 800
    165/65R14 MICHELIN ALPIN A3
    For rear tire:
    MINE: Kumho AST 225/50-R15 Federal 225/50R15 SS-595 91W
    Fulda 225/50R15 Cart extremo
    Michelin 225/50R15 PI.Exalto PE-2
    Toyo R888 225/50R15, approved for road, but not good under rain (aquaplanning).
    Pirelli P Zero A
    Dunlop SP9000
    OTHERS;
    REAR - Toyo Proxes 4, Michelin HydroEdge 215/60R15, Falken ZE912, Kumho Sabji.
    FRONT - COOPER CS3 185/60 R 14,
    take your pick
    Dan P
    Easley, SC
    SPYD3R
