Page 2 of 2 FirstFirst 12
Results 26 to 47 of 47
  1. #26
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default Did not know that
    Quote Originally Posted by Illinois Boy View Post
    From what I have read and re-read a dozen times trying to wrap my brain around this issue, I have discovered that DB levels (or claimed DB levels) means nothing as stated by manufacturers.
    The first problem is how the manufacturer has measured for a DB level. There appears not to be a standardized testing method used; thus stated (advertised) DB levels are not consistent among the various products. Testing has been found to have been done at varying distances from the source; thus nullifying any meaningful comparison between two products.
    Also, the "note" of the horn(s) can make a difference in how well it is heard by the human ear. It is also known that a more dissonant sound, typically provided with the use of two horn reeds, is more noticeable than a truer tone/note despite any fact of any difference in actual DB levels (to a degree).
    Personally, I would like a loud horn sounding exactly like car tires screeching to a halt on hot pavement. I suspect it would get people's attention if needed.
    Side by side , it's obvious they roll out of the same factory. I bought a bad boy three years ago at HF for 35 bucks. It plays a loud kind of high pitched chord. Sounds like two trumpets. It's been great. I did use the relay that came with it.
    it was fun while it lasted.
  2. #27
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    I installed my Stebel Nautilus today. It sounds great!!
    Pam
  3. #28
    Mar 2015
    forrest above Reno, Nv
    Smile Me too!
    Stribel horn arrive today and is already mounted. Easy farkel, and functional too as the stock horn is usless. A few minutes of wiring tomrrow and it done. Now i have 3 stribels and one bad boy.
    Kaos
    2014 RTS , Circuit Yellow
  4. #29
    Mar 2015
    Thumbs up Installed
    Wiring for the above install done and boy is it LOUD.
    Kaos
  5. #30
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by kaos View Post
    Kaos
    YUP, NICE AND LOUD!
    I installed mine last week.
    Pam
  6. #31
    Albion,Michigan
    Smile Your Installation of Stebel on your 2013 RTL
    Quote Originally Posted by Copperman View Post
    I can't recommend enough the Universal Plug-n-Play Wiring Harness for Motorcycle Air Horn
    you can buy on Amazon for $19.95. It makes the install very easy and has a heavy-duty 30 Amp relay built in. It's plug-n-play folks! No cutting, splicing and/or soldering. Very easy!
    I used one on my '13 RTL when I installed the Stebel air horn.
    If have a couple of questions that I need help with. Which side did you install your horn on, and the second question concerns the correct way to wire the plug and play wiring harness to the Spyder and the horn. Thank you in advance for your time and information/instructions. Dave
  7. #32
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by AH-NO-1 View Post
    On my '13 RTL I had to remove the frunk to install the horn in the same location as the stock horn. There's a black plastic piece that has a small (2 x 2) hole cut in it that the OEM horn opening sits next to. You have to take a dremel tool and expand that hole so you can reinstall it over the Stebel. It takes a few times to measure, cut, fit, measure again, cut a little more, refit, etc so that you don't cut the hole too big. Then, it all fits back together.
    As far as the wiring goes (now, this is off the top of my head), the lead with the fuse hooks to your battery. The relay is already attached and its lead connects to both the horn wires and the horn itself.
    Hope this helps.
    Feel free to call with questions.
    Jerry
    317-445-1411
    2020 RT Limited , Chalk
  8. #33
    Sep 2013
    lake mary fl.
    Default bad boy
    Quote Originally Posted by outlawsix View Post
    Just posted to your video. I knew I should have looked here first. Im guessing our RTS are a tad different. I tried to mount it where you did to no avail, no space, Mine has a "junction" for my battery wires on the left side of the bike right at the top of the Frunk. Looks likes yours doesn't have it there? Trying to get it set up tomorrow, so any input from yourself or others with 2013 RTS is greatly appreciated. Thank you in advance.
    Hi there! I know exactly what you mean as far as the location! I installed mine on the right side of the bike, right under the plastic by the fog lights! You'll have to make a bracket n bolte it to an existing body bracket on the bike! Can't missed! Once you remove the plastic you'll see it! I recommend using the relay switch! To me it sounds louder with it! Hope this will help!
  9. #34
    Invalid Emails
    Aug 2015
    WISCONSIN
    Default AIR HORN
    I also have a 13 RTL and have been considering on getting an air horn. Did the air horn fit in the same position as the oem part? Did you have to modify anything to make it fit? Approx. how long did it take to do the installation. Thanks for any input.
  10. #35
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by SPIDR1 View Post
    See post #32.
    It took a couple of hours, if I remember right. A guy I know, who's a mechanic, helped me.
  11. #36
    Oct 2015
    Wales
    I mounted mine - and its relay, fed through a 20A fuse from the battery - in the nice big empty void where the original horn sat.
  12. #37
    Feb 2015
    Southern Maryland
    All this talk about Stebel, I had to get one and install to see for myself what others are saying. Well, I really like it!
  13. #38
    Feb 2015
    Southern Maryland
    ...here are a few more pics and of the 20 APM fuse. I used the relay that came with the horn and made my harness. This made wiring really neat and clean.
  14. #39
    SpyderLovers Sponsor lewis/ec's Avatar
    Apr 2013
    TN, Knoxville
    Quote Originally Posted by ThreeWheels View Post
    I can't imagine that ANY handlebar mounted switch can take anywhere near those amps.
    There has to be a horn relay someplace in the circuit. Evidently it's sized with enough safety factor to absorb the additional amps.
    Few points to consider.
    1. Just because a circuit is fused at 5 amps, does not mean it uses 5 amps. You have to have a buffer in there to compensate for the 'current inrush'. The factor I use is 150%. So if the load is 3 amp, you multiply that by 150%. 4.5 amp. You use the next fuse size up....5 amps.
    2. More than likely, there are other items on the same circuit as the horn. I have ordered full electronic manuals for the Spyders....but this is based off other vehicles.
    3. There is a reason the horn manufacturer includes the relay. Most of these air horns draw 3 times what your stock horn does. The OEM wiring and connectors were based on that stock load.
    4. Damage does not happen after one or two operations. It takes a bunch. But here is what happens....you break the weakest link. Might be a switch, might be a fuse, might be a connection. When you do find it, you get to spend a bunch of time on a Easter egg hunt that could have been totally avoided.
    One other point to consider....orientation. The horn needs to be straight up and down, no more than 15 degrees off. Otherwise, the bearing in the compressor housing will get destroyed.
    lighting - electrical - tutorials @ Electrical Connection
  15. #40
    Apr 2013
    TN, Knoxville
    Quote Originally Posted by coz View Post
    The Stebel is made in Italy. Wolo Bad Boy is all China.
  16. #41
    Mar 2016
    CT
    Quote Originally Posted by lewis/ec View Post
    thanks Louis.
  17. #42
    May 2016
    Chillicothe, OH
    Default So do any of you...
    Live in Southern Ohio? I want a loud horn on mine but mechanical work is not one of my gifts.
  18. #43
    Active Member SuperDave_GPS's Avatar
    Mar 2016
    Kingston, Ontario, Canada
    Default I agree.
    Quote Originally Posted by PatriotRider View Post
    no relay...5amps vs 12amps
    the question is does the current go through the horn button...if so and I suspect it does, it's not wiring that will be damaged over time, it's the horn switch not designed for 12amps, even in shortish bursts. That's the reason in these instances, the relay well may be the way to go, preventing switch problems
    IMHO...your mileage may vary
    I agree completely. I teach electronics to military students, and I would agree that the higher current going through the contacts inside your horn switch will kill the switch over time, even if using "short bursts".
    There IS a reason why a relay is included.
    SuperDave_GPS
    "Rosie"
    2016 RT Limited
  19. #44
    May 2013
    Stanton, ca
    Quote Originally Posted by SuperDave_GPS View Post
    2 years later still working!
    Several others also not using the relay have had no issues as well.
    I was in a parade last year and used the horn a lot. No issues.
    But with that said, use the relay to be sure.
    Bob
  20. #45
    Very Active Member Sopher's Avatar
    Feb 2008
    Just outside of Boston
    Hey Finless, long time since our paths have crossed... since way back in the RC Heli days... Trex 450 i think. Loved your build videos.
    I have a 2010 RTS. Is the wiring and mount of the old horn the same as yours? I could have sworn it was on the right side. (oposite of yours).
    I cant use the mounting location you did anyway since my Beaver Power Distribution box is located there.
    RT-S # 352; Timeless Black... faster than any other color. Mods: EasternBeaver PC8 Fuse Box, 12v digital dashboard display, RearTrunk internal Lights.
    Pioneer XMP3 hardwired, KewlMetal highway foot rests, PolkAudio Speaker upgrades (dxi525 & dxi400), Custom Garmin Nuvi bracket and wiring, Panel Savers, Custom LED array third brake light and rear signal LED's. Custom mud flap lights. Daytime Running Lights (3wattsx6). Heated Corbin seat with 'Lamonster' cut. JBL 400watt Amp,
    Other secret mods.
  21. #46
    Sep 2016
    dilworth,minnesota
    Default horn
    does anyone make horn that sounds like an old buick
  22. #47
    May 2013
    Stanton, ca
    Quote Originally Posted by Sopher View Post
    Yes 2010 - 2012 should be the same. It moved to the right side in 2013 as I recall.
    Bob
