Page 1 of 2 12 LastLast
Results 1 to 25 of 47
    May 2013
    Stanton, ca
    Default Bad Boy (same as Seibel) Air Horn Install tips video
    OK folks, this was an easy job compared to my last one!
    Took a little figuring to find the best mounting place but once I did, install was easy peasy!
    I did not make a full how too, just a quick video on how I did it which should be easily understandable.
    FYI, to me this is a GREAT upgrade over the stock "Meep Meep" horn. I recommend it.
    Bob
    2011 RT-S SM5 - Black
    Default Nicely done..!!
    great video and explanation on aur horn installation. I also ran stock wires and was told I will blow the fuse after 30 sec's. To which I reply if they didn't hear it in 10 they're not going to.... Works great...thanks..
    ​2012 RS sm5
    May 2013
    Stanton, ca
    If your a "horny" guy then add the relay! What I mean is, if you use it a lot and long durations... Add the relay. No offense to NY City folks but it's a daily instrument for them! So maybe you should consider it..... Kidding yet not kidding
    I am with you Cupa, I have never needed a horn more that 10-15 seconds!
    FYI, just as a test I held it for 30 seconds. It did not blow the fuse and the wires were not hot. So to some extent, I think the horn circuit seems to be over engineered as most electrical systems are. The fuse is there and blows due to a short or extreme overload. NOT normal use even with some overload! Personally, the Sypders horn setup is perfectly fine using the stock wiring with this slightly higher load demand.
    Just my opinion.
    Bob
    Active Member outlawsix's Avatar
    Jun 2014
    Picayune, Ms
    Just posted to your video. I knew I should have looked here first. Im guessing our RTS are a tad different. I tried to mount it where you did to no avail, no space, Mine has a "junction" for my battery wires on the left side of the bike right at the top of the Frunk. Looks likes yours doesn't have it there? Trying to get it set up tomorrow, so any input from yourself or others with 2013 RTS is greatly appreciated. Thank you in advance.
    2013 RTS SE5
    Jun 2010
    Las Vegas
    There is loads of room in the 2014 for this horn. I had Pops install one for me in Durango and it sounds great. Scares me if I hit it by mistake!
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Albion,Michigan
    Red face THanks for the- Air Horn Installation Instructions / Video
    Quote Originally Posted by finless View Post
    Bob
    Thank You, when I get the spyder back from the heat recall, I a am going to install the horn that arrived last week. Thanks again -Dave If you did not receive my first Thanks, I am still in the learning process on my computer.
    Active Member Upstater's Avatar
    May 2015
    Upstate NY
    Default New horn installed
    Bob
    Thanks for posting the video. I was able to install a new Bad Boy horn with relative ease. Fabricating a bracket took more time than necessary, but it worked out fine. Installed the new horn in the same spot as yours. The help on this site is invaluable. Extra thanks to you and all the other Spyder folk for making these jobs easier.
    2012 Spyder RT SE5 Limited - Lava Bronze
    - Baja Ron Sway Bar - SmoothSpyder Belt Tensioner - Air Modification Kit - Motorcycle Dave's gel seat inserts
    - Rivco Floorboards - Show Chrome Trunk Rack - Bad Boy Wolo Air Horn
    - FZ-1 Fuzeblock - Hopnel Lid Nets - Monster Graphics
    Active Member WARWAGON's Avatar
    Feb 2013
    Hamilton, Ohio
    Just got a 2015 RT limited need spot to put horn. Any input?
    Steel Black Metallic 2015 RTS-SE6 Limited ; FBB Highway Brackets/ gripper pegs. Gremlin bell. Bajaron sway bar, Elka stage 2 front shocks. Bumps kid with led lights, Ultimate seat tall boy seat. Trailer hitch. Freedom trailer.
    Active Member PatriotRider's Avatar
    Sep 2015
    Metairie, LA suburb New Orleans
    Default Piece of Cake
    let's ride safe & be careful out there,
    Mike in Nawlins'
    2014 Black SE6 Limited "Charlotte"
    New Orleans Ride Captain
    Patriot Guard Riders
    Sep 2015
    no relay...5amps vs 12amps
    the question is does the current go through the horn button...if so and I suspect it does, it's not wiring that will be damaged over time, it's the horn switch not designed for 12amps, even in shortish bursts. That's the reason in these instances, the relay well may be the way to go, preventing switch problems
    IMHO...your mileage may vary
    Mike in Nawlins'
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    Default Which one to order?
    I want to order this horn on Amazon, but it asks which vehicle it's for. On the pulldown list, there isn't a choice for any motorcycle brands, including Can Am.
    Does it make any difference? I'm guessing it just has to do with the mounting hardware
    Thanks,
    Pam
    P.S. Disregard. I failed to noticed the radio box choices above the selections where I should have checked off "Motorcycle". My bad
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Sep 2015
    As far as I know, some of them sold for 4 wheelers come with a bracket arm bent to fit that particular car.
    I purchased one for every bike I've ever owned and there was no bracket, and I never specified what bike I had. The one I purchased off Amazon last week for the Spyder just mentioned it was for a motorcycle. Mounting hardware is up to us to provide.
    Again, I believe all that is true from memory & experience
    best to ya
    Mike in Nawlins'
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by PatriotRider View Post
    best to ya
    Stupid me! I failed to notice the choices where I could have checked off "Motorcycle" Can Am IS listed there
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Danbury Connecticut
    Quote Originally Posted by WARWAGON View Post
    Finless,
    Once again you prove that you have a powerful skillset.
    As to the 2015 RT, it's easy to install the Wolo Bad Boy or Stebel as a 1 to 1 replacement. The new horn fits in the same place as the old one with a small modification to the installation bracket.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Danbury Connecticut
    I can't imagine that ANY handlebar mounted switch can take anywhere near those amps.
    There has to be a horn relay someplace in the circuit. Evidently it's sized with enough safety factor to absorb the additional amps.
    IBA #47122
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by ThreeWheels View Post
    I can't recommend enough the Universal Plug-n-Play Wiring Harness for Motorcycle Air Horn
    you can buy on Amazon for $19.95. It makes the install very easy and has a heavy-duty 30 Amp relay built in. It's plug-n-play folks! No cutting, splicing and/or soldering. Very easy!
    I used one on my '13 RTL when I installed the Stebel air horn.
    2020 RT Limited , Chalk
    Jul 2011
    Mitchell, Ontario, Canada
    Nope no relay. All the current goes through the switch.
    2018 F3 LIMITED
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by Copperman View Post
    Thanks for that tip Copperman. I just ordered the wiring harness you recommend, and the Stebel air horn. The reviews on the Stebel much more favorable than those on the Bad Boy.
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by Pampurrs View Post
    Pam
    You'll be glad you did. The horn fits in the same location as the OEM horn and the wiring is pretty simple, too.
    Sep 2015
    Default Wolo made wiring kit on Amazon
    when I was looking to purchase a horn and wiring, I came across this wiring kit make by WOLO for $8.53. It was the only one I ran across at the time. It does not have the relay itself enclosed, only a socket for one...I think the assumption is the relay comes with the horn.
    Wolo (MCHWK-2) Air Horn Wiring Kit
    http://smile.amazon.com/gp/product/B...ilpage_o06_s01
    <my intent is NOT to slam the stebel kit in any way>
    Mike in Nawlins'
    Mar 2015
    San Tan Valley, AZ
    Byen Merci
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Mar 2015
    forrest above Reno, Nv
    Thumbs up not the same
    The Stribel and the "bad Boy" horns are NOT the same by a good margin. I have the Stribel on my Valkyrie and a badboy on the V-Max ( bothwith relays). You can easily tell the difference and the Stribel is a real step up.
    OEM horn is useless. A Stribel horn is my next farkel.
    Kaos
    2014 RTS , Circuit Yellow
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default How are they different?
    Quote Originally Posted by kaos View Post
    Kaos
    i thought they had roughly the same sound and decibels.
    it was fun while it lasted.
    Mar 2015
    Thumbs up Thin air up here
    Maybe it's the thin air at 6,000 ft but I honked them side by side( with freshly charged batteries) and I'm NOT mounting a "bad boy" on my . THe Stribel is the way to go.
    Wimpy OEM horns cause:
    Kaos
    Sep 2011
    North Central Illinois
    Quote Originally Posted by coz View Post
    From what I have read and re-read a dozen times trying to wrap my brain around this issue, I have discovered that DB levels (or claimed DB levels) means nothing as stated by manufacturers.
    The first problem is how the manufacturer has measured for a DB level. There appears not to be a standardized testing method used; thus stated (advertised) DB levels are not consistent among the various products. Testing has been found to have been done at varying distances from the source; thus nullifying any meaningful comparison between two products.
    Also, the "note" of the horn(s) can make a difference in how well it is heard by the human ear. It is also known that a more dissonant sound, typically provided with the use of two horn reeds, is more noticeable than a truer tone/note despite any fact of any difference in actual DB levels (to a degree).
    Personally, I would like a loud horn sounding exactly like car tires screeching to a halt on hot pavement. I suspect it would get people's attention if needed.
    SL #7026
    VBA #652
    HOG #3935417
    2011 Viper-Red Spyder RT SE5 & Trailer
    2017 HD Ultra Limited
    Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
    Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
