Anybody had......
moisture get behind the glass of the speedo & tach??? Is there a way to clean this up and seal the glass??
Side note----wife and I are experiencing echo with our SMH-10 headsets. Happens when we set behind one another on the spyder. walk about 10 feet
apart and voice is normal. We have done all the updates and released the parings each time. Did not have this problem when we got these. Have tried
twice emailing and twice calling Sena with no answers at all. I am getting pretty disgusted with the lack of support I am receiving from them.
Anybody got any ideas???
Thanks,
Bob
I had a smudge under the plastic on my 2010 and it was driving me crazy. I removed it and tried to clean it off and really only made things worse. It seems like the plastic is treated with something and if you try to wipe it you remove it and make a mess.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
It might just be best, to contact your dealer...
How old is your bike?
Has it been exposed to unusually wet or humid condtions?
I'd probably try a hairdryer on the gauges first...
Good Luck; please let us know what happens next!
This is a 2014 RT-L I am talking about. The moisture left a streak trail inside the glass and if the light is just right I can see it. No, the bike has not been ridden in the rain nor gotten rained on since I purchased it. It resides in the garage at all times.
Any comment on the headset problem???
Thanks,
Bob
RTs have had an issue with moisture. Both of ours, 2010 and 2012 have the streaks. Since yours is under warranty, take it back to the dealer. You do not want to remove and disassemble the panel to clean it.
Regarding the echo, you're getting feedback. We have the Scala 9 and they will echo riding two up. We have no issues getting tech support on them.
USAF '69-'89 E7
Thailand/Vietnam 1972
The lens is replaceable on RS. Is it not on an RT???
2018 F3 LIMITED
Yes it is. About 20.00 I believe.
USAF '69-'89 E7
Moisture will develop due to temperature difference.to other member to use hair dryer and please be careful. Let us know the result.
2012 Spyder RT SE5 Brake pedal mod
Courtesy of Lamont. This is what the display looks like in pieces. If you're going to take it apart, be very careful f how you handle the module. A static charge can fry it without you knowing it.
USAF '69-'89 E7
That looks just about like something; that I hope to NEVER see!
Thanks,
I have the same problem and was not fixable, due to there not a replacement part. If you go to an auto parts store they may know someone that can repair or make a new glass. That IMHO.
Mike
2018 F3 LIMITED
The plastic cover is available as a separate part. Part number is 415129349. BRP refers to it as a lens.
USAF '69-'89 E7
I just looked it up and it is the same part number for my ST.
2018 F3 LIMITED
2014 sounds like a warranty deal.
Originally Posted by billybovine
Bruiser says you can buy a new part for 20 bucks and you say you can't.
I was told by a dealer the plastic cover was not available. Thanks for the part number. I'm going to order one for the fall when I change to the winter windshield.
Mike
Thanks,
I have the Sena SMH 10 as well and noticed the same problem after the latest update,the echo is annoying.I may just go back to the previous firmware as I had no problems with it also never found any noticeable improvement with the last version.You can go into the Sena device manager and reload any of the previous versions.Hope Sena addresses the issue.
Blue Tooth
We are not using Sena but when the battery is almost empty we are getting an echo, it is a Blue Tooth problem with some devices.
This message was sent between rides
Bob
