Results 1 to 20 of 20
    Active Member Barlock's Avatar
    Sep 2013
    Alberta, Canada
    Default Dealership said No
    I wanted to remove two useless gauges (fuel and temperature) by disconnecting them and having their equivalents to appear on my central display. Then have those disconnected gauges replaced by a dash power socket for my GPS and a digital voltmeter. I bought all spare parts and wire harness.
    When I called my dealer and asked them for a quote, he absolutely categorically refused to do that, because my spare parts are after market, which means they are not BRP original ones.
    I could also do it all myself, but I'm afraid that would affect my warranty.
    Thoughts?
    2012 RT-S SE5 with Web Boards, custom graphics and battery tender leads
    Default Choices choices..!!
    I would do it. I can not see those add ons affecting your warranty. Dealers can be fussy about aftermarket products on vehicles with factory warranties. We have seen a great many doing similar and more...
    ​2012 RS sm5
    Registered Users Gray Ghost's Avatar
    Sep 2013
    Harper, Texas
    Quote Originally Posted by Barlock View Post
    Thoughts?
    Look up the Magnuson-Moss Warranty Act online. Basically the federal law says that for something to affect your warranty, the dealer must be able to show that the non-OEM part was the cause of the failure.
    Clifford Fargason
    2013 Spyder RTL
    2007 Royal Star Venture
    Jul 2010
    Las Vegas, NV
    Default Bull
    Find a new dealer.
    Do it yourself. Takes just a few minutes.
    Joe Meyer
    Very Active Member BikerDoc's Avatar
    Clermont, Florida
    Quote Originally Posted by cptjam View Post
    Find a new dealer.
    You definitely need a new dealer no matter what you do on the gauges. This one is either a liar or incompetent or more likely both
    220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
    Very Active Member ARCTIC's Avatar
    May 2012
    IOWA
    I can totally understand why they don't want to do the customization portion
    2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
    Well; it won't void your warranty as long as your wiring is done correctly, and poses no electrical issues...
    Try another dealer: GOOD ADVICE!
    Sep 2013
    Alberta, Canada
    Thanks everyone for your advices. Most of them are about finding a new dealer, and that is exactly what I cannot do. There is only one BRP dealer in town with 2 locations in different parts of city.
    The disconnect is a 5 minute job or so. Even I, Mr. Non Mechanical, was able to accomplish the disconnect. Can't possibly see why it would affect the warranty. When the analog gauges are disconnected the digital gauges pop up automatic. They are also more accurate than the previous to 2014 analogs.
    Adding other gauges is another question. My dealer would also not do that for me. No word was said about voiding the warranty though.
    Sounds like you are on your own to install different gauges.
    Very Active Member SNOOPY's Avatar
    Aug 2013
    How about another cycle shop?
    Dont think that such a thing is proprietary to a BRP product, any good tech can do an install.
    And even perhaps the service writer at your other BRP dealer is more lenient toward such things...
    Charlotte, NC
    Since it's after market the warranty impact is the same no matter if you do it or the dealer does it. And the impact only matters if you cause a problem due to the wiring...it won't just void a warranty.
    Very Active Member rcturner's Avatar
    Jun 2012
    Fairmont, Minnesota
    I believe that most dealers would not even consider doing this. Taking the old gauges out should be no big deal. The issue would center around the pieces you brought into the dealership to have installed. If there is a problem with them, your dealer would have the original cost of their work plus any labor and/or materials that they needed to incur to correct the problems related to your parts. To them, it simply is not worth the potential hassle plus, if they charged you $75 plus per hour to work on these issues, you won't be very happy with them. It is simply a lose lose situation for them and a potential hassle they don't need.
    Banged Up Member MouthPiece's Avatar
    Dec 2009
    Sanford, Florida
    Quote Originally Posted by SNOOPY View Post
    Excellent suggestion. There are some "cycle shops" out there (and perhaps in your town) that will work on spyders. We had one here in Sanford, Flarda, "scooters" until he/John decided to move about 20 miles east of here. He owns a spyder, but works on motorcycles and does some work on spyders too.
    Perhaps you might have someone like this too?
    Chris
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    Default Another approach
    Given your situation perhaps a second approach to someone in more authority at the dealership may be in order. I would explain that there are hundreds (maybe thousands) of Spyder owners who have added auxiliary gauges to their machines and many of those have been done at Can Am dealerships.
    I installed the voltmeter myself but the OP gauge seemed out of my league so I had the dealer install it when the first service was due. I supplied the gauge and the adapter required and it was installed with no problem.
    Attached is a copy of the OP gauge work order from my files. Note how the dealer covers themselves in the print at the bottom of the order by saying 'parts carry a warranty through their respective manufacturer'. You might want to share this information with them.
    As it turned out I could have done the install myself after watching it done but now that it is added, I have yet another way to monitor the performance of my Spyder and that would seem to be an important factor.
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    Very Active Member bluestratos's Avatar
    Jun 2011
    Lynden, WA
    Since technically the gauges are optional they should at least able to remove them. He may have an issue with installing aftermarket but then will he install anything aftermarket? Lights? Muffler? They cannot deny warranty unless the actual problem is directly related to the aftermarket part so he is wrong but he can refuse to install anything they feel they are not competent to do.
    Take the bike to the other dealer for the install, use the local dealer for the low brow stuff and warranty work.
    Sep 2013
    Alberta, Canada
    Quote Originally Posted by Double Trouble View Post
    Thank you. This sounds like a very good suggestion. I will try and see what happens.
    Idaho
    Quote Originally Posted by Gray Ghost View Post
    Oops. Doesn't apply north of the border!
    Sep 2013
    Harper, Texas
    Quote Originally Posted by WasWinger View Post
    Missed that. Thanks for the catch
    Clifford Fargason
    2013 Spyder RTL
    Sep 2013
    Alberta, Canada
    It may not apply directly as a law, I agree, but the logic should still apply. Shouldn't it?
    In any case, what I've learned from this conversation is that at the end of the day I'm on my own in sorting this out and no dealer would step up to the plate to help me. Oh well ... not a big deal - not a first (and not a last) time in my life when I need to make those kinds of decisions.
    Thanks everyone and cheers.
    Jun 2014
    Muskego, WI
    The dealership guys are just trying to avoid a potential problem with the customer supplied parts. They obviously must have enough customer service work waiting in the wings that they don't need anymore work i.e. income. I would check at a few more dealers. Most will install anything you want as long as you pay for their time and what you want to install is street legal in your area. The obvious "out" for them is to put a disclaimer on the work order that stipulates they are not responsible for the performance of any customer supplied parts. In my area the install/labor would likely be covered for 30 to days 90, but no dealership warranty would be given on the parts themselves. Strange situation and one that literally takes food off the plate of the dealership. Not very good business sense for the dealer.
    Rick
