Results 1 to 11 of 11
    Jun 2014
    Strongsville
    Default Resetting Shifter On SE5
    My shifting has been a little rough in the early gears. Seems to be getting worse. I'll check the oil, though I just had an oil change recently and it was shifting fine.
    A tech at one of the dealers said that they can reset the shifting points, essentially clear it out and have the computer relearn them. He thinks that might help smooth it out. Has anyone had this done or heard of it?
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Quote Originally Posted by mpapatonis View Post
    A tech at one of the dealers said that they can reset the shifting points, essentially clear it out and have the computer relearn them. He thinks that might help smooth it out. Has anyone done this or heard of it?
    I would like to know too keep us posted.
    Ride safe!
    2022 Sea-T0-Sky
    May 2013
    Stanton, ca
    Requires hooking the Spyder to BUDS system.
    Bob
    Jun 2014
    Strongsville
    Ya, that's what the tech said. Have you had it done?
    May 2013
    Stanton, ca
    No as I have a SM5. But I have read here about others that have. Not sure if I recall if it helped or not.
    Bob
    It's probably just as important to make 100% sure that the oil level is where it should be...
    These bikes get cranky if they're about 6 drops low...
    Jul 2010
    kansas ottawa
    you also should check your oil after the dealer changes it they over fill most of the time,ive had to drain some out ever time i let them change my oil.
    Jun 2014
    Strongsville
    Too much oil is as bad for the shifting as too little?
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by napper39 View Post
    I'll bet that is because they check it cold. Manual says to check it at running temperature. It makes a TREMENDOUS difference. When I check mine cold, it was way down at the bottom of the dip stick. After heating up the engine, I found that it was significantly over full. Strange.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Default Shifting..!!
    they can reset the shift points but if you have the se5/6 only. This would be the automatic down shifts. So like Bob said it's mostly about the oil..type, condition, filters etc. Also that issue of letting up on the gas between shifts on the semiautos. Remember oil condition also affects the clutch operation..!!
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    Dealer should know exactly how much goes in during an oil change! I always have 1/2 a litre give or take left over when my dealer or I do it, as they take 4.2 litres(4.4 qts) so if they are overfilling, they are not very good techs and not following the specs! JMHO!
    2012 RT , stock Lava Bronze
