GOS member (Girls On Spyders)
VSS
Getting a VSS error and Limp mode today. Not near a dealer and it's the weekend. What can be the problem.
2014 RT SE6 Limited
rYding Safe = Having Fun
Ruthie
Let's see..!!
if you do the key walk..pull the key walk away for a while then return and restart..this may reset the computers and clear the codes and lights. I usually get it when going through a long sweeping banked turn where the engine just cut back to a crawl but that clears it up. This is not to say there may be something else in the stability system. It is a sensitive system but keeps you safe...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
