Any One Else?
I have a 2012 RT Ltd. and replaced the cat with a bypass and the stock muffler has a slight rattle in it that wasn't there before. Any one else have this, or am I the lucky one? I like the deeper tone, but not sure about the rattle.
J. D.
2016 F3T Magnesium Metalic : Smooth Spyder Dual Backrest, Lamonster LED Head lights and Fog lights
SpyderLovers Sponsor
J. D.
All you need to add is the 'Shake' and 'Roll' and you'll be famous!
Sorry, it's the only help I can give on this one!
J. D.
Strange but I have the same thing after Pitbull install at Durango. You hear it every little bump. Will check further when we get home.
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Little checking..!!
you need to check all the mounting point, clamps etc involved with the modification. If it is internal (muffler) check with the dealer.
2012 RS sm5
2021 Sea To Sky, 2020 RTL
but our benefits don't?
I have the same issue on my 2010 right after the cat by pass which started right after the install. I tried the rubber mallet test up and down the exhaust with no luck. I'm wondering if it's inside the muffler itself.
SpydermanCT
2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
Friend of mine had the same issue on his 2010 RT. Culprit was baffles inside muffler had come loose probably from corrosion, old age or ... . Dealer replaced under his extended warranty...think it cost him $50.
2016 F3-L Special Series? Mods: Lamonster IPS end caps w/ Gripper 3rd pegs, GPS mount, Power Plate, Perf. Muffler; Backoff Brake Light Strobe; CD Front (amber/red) Brightsides & Tip Kit; ISCI Flag Holder w/Long Poles; BRP Signature Light, Aux Lights, Saddlebag Liners, Garmin 590 GPS; TricLED foam Grips, LEDs (Aux/headlights); Pitbull Driving Lights; RDL seat; Ultimate backrest
Previous ryde: 2012 RT-L, 26,636 miles on it when traded; 2014 RT-L, 34,147 miles on it when traded
RT-S PE#0801
muffler rattle
J. D.
I have a 2010 & it started to give me that strange rattling exhaust noise recently, I am almost 100% positive a baffle has broken loose in the muffler and it keeps getting louder (rattling sound) with ever ride.
2012 here with same problem after I installed bypass..Tight, no clamp issues or leaks. Only did it when it was cold. Did it for a few months. It's either gone away or I've gotten so used to it I don't notice it anymore.
Mine didn't do that...odd, I am very gentle with the parts as I remove them, but I can't imagine someone dropping the muff while it was off hard enough to break anything internal,
There's that sound of the loose nut behind the handlebars, but that's always been there.
Eric
YNC(SS) (Retired) - U. S. Navy Submarines
2014 RT-S Cognac
3 seadoo's,CBR250R, Suzi GT750 waterbuffalo's x4, Rebel 250, MB5, '84 Alfa Spider, '97 Jeep TJ, '93 Saab C900CVT, '99 SLK230, '65 Mustang, '59 Fairlane, '48 Ford 8n
same here
dealer swapped out muffler under warranty but still had that tinny rattle when cold especially. dealer got me a decent price on the acrapovic sport touring muffler ,problem solved didn't want to spend the money but it does sound much better
2014 rt-s black,bump skid,baja ron swaybar and shock spring adjusters,rivco highway mounts &pegs and trunk flag holders 2014 900 ace renegade
