My upper heat block mod
The heat from the radiator on my 2013 RT was too much for my foot when I have it up on my highway peg. I decided to make my own using a 2014 RT right side grill.
First I cut the bottom of the grill and a couple of tabs off and then heated and reshaped the bottom to more closely match the shape of left side grill.
Next I cut a piece of aluminum sheet to fit the perimeter shape of the grill. Using aluminum duct tape I taped it to the grill plastic. Aluminum duct tape can take the heat and sticks for ages. It's painted flat black on the side that shows through the grill.
I cut a couple of holes in the duct plastic behind and below the radiator. I had earlier removed the bottom plastic shield when I installed the Spyder Pop's Bump Guard. Then I used a Dremel with a right angle attachment and spiral cutter to enlarge the hole. This is to allow as free a flow of the radiator air as possible.
Nicely done..!!
great job. That will certainly fix the problem of heat on your foot when on the highway pegs. Looks great and others can benefit from the pictorial...thanks and congrats..!!
2012 RS sm5
This is really ingenious! Ever think of marketing a kit?
Dan
2012 Viper Red Rt
upgrades:
Baja Ron's Anti-Sway
Diamond-R Arm Rests
Gloriders
High mount brake light
chrome front fender garnish
Bad Boy Horn
Chrome Deflector Rack
Chrome Scuff Nose Accent
Handlebar Grip Fringe
Gremlin Bells
Very Nice !
I will be building one this week. Does your temp stay good on the gauge ? Thanks, Chuck
Yes.
2014 Copper RTS
Can I use these parts and process on a 2011?
Dick Harding
Boise,ID
2011 Spyder RT SE5 Limited
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!
Large1 is online now Report Post
Being new to Spyders, I wonder....
Originally Posted by IdahoMtnSpyder
Here's a pic of the grill in place. I left the tab on the grill and drilled a hole the same size. A push pin left over from the bump skid install holds the grill in place.
This is what it looks like when finished.
Best of all, in what little testing I've had time to do, it works great. I can now leave my foot on the highway peg without it getting burned up.
...what effect blocking this air flow has on the engine? I have read about blocking the hole, but how does the engine get enough air flow to keep cool? I have a 2010 RT SM5... and my foot gets HOT!
Ryde, eat, sleep.... repeat
2019 Spyder RT Limited Pearl White/Dark
LaMonster drink holder with X-Grip
LaMonster Belt Dampener
Lamonster USB cable with extension
Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
Thinks out loud
Hot enough to pop corn
He blocked the upper but the lower is still open. If you notice he uses highway pegs and blocking the upper keeps the heat off when his legs are up. Would still get the heat if he was on the stock pegs. It's a trade off....block one or the other but not both and you'll be fine.
Edit: If you do not have the NEW upper air vents that came about because of the heat issues, you should do that too. Those, along with blocking which ever radiator discharge hole you decide on will make a world of difference.
Remove the plastic panel underneath. I don't know if the 2010 has the plastic shroud like I show, but if so you have to cut a hole in it. Yeah, you do have to make sure you leave a path open for the air to flow away from the radiator. I saw no heating problem.
2014 Copper RTS
Thinks out loud
FYI
Thanks for sharing. Yankee ingenuity at it's finest!
He's on his RT She's on her F3
And the Keys to a Happy Marriage: Separate
Bathrooms, Individual Remote TV Clickers, and
His and Her Spyders.
"If there are no dogs in heaven, then when I die,
I want to go where they went." ~ ~ Will Rogers
"Never in the field of human conflict was so much owed by so many to so few."
~ ~ Winston Churchill in his tribute to the RAF.
"I'd like to know why well-educated idiots keep apologizing for lazy and complaining
people who think the world owes them a living." ~ ~ John Wayne
GOS 3799
