SpyderLovers Sponsor
Originally Posted by PMK
I went by the local dealer and picked up a filter. Took it in the shorts on price. Retail is $15.99 and they charged $19.29.
But FWIW Broward Motorsports in West Palm has a bag of filters if anyone needs one.
Filter PN is 420956743
Dimensions are as follows
Overall length excluding grommets 98.3mm
Overall length including grommets 106.7mm
Outside diameter (metal edge) 56.5mm
Inside Diameter (grommets) 25.0mm
Consider that the grommets must be able to handle the pressure diff across the filter element.
PK
The grommets are just to seal the ends. Usually a filter only needs 1 end open, otherwise the oil could enter and exit without going through the filter at all. Even filters with 2 grommets don't necessarily need them (as in the original OEM trans filters) as the 2nd grommet simply seals against the outer cap. They could just as easily (and more cheaply) put a blind end cap on the filter itself.
If this was the case with the 1330 ACE motor we could simply use the engine filter used on all of the earlier models. But, in this case it appears both ends being open (with grommet) is functional and the system will not work without both ends being open.
This is what happens when you re-invent the wheel.
Both ends are open to allow the bolt to pass through. They need to seal to prevent bypass of contaminated oil.
PK
Exactly.. !
So you take one of the older type, put a hole cutter in your drill press, drill out the metal end, add a grommet off the OEM you just removed! I've got two prepared, but haven't the urge yet to try them; besides I have an extra OEM on the shelf!
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Originally Posted by ulflyer
Assume you mean this one? http://www.ebay.com/itm/OIL-FILTER-S...e9addc&vxp=mtr
Buy one and send me the measurements and I'll compare it to the new '14 filter that I have on hand.
May stop at my dealer tmr; if so, will compare the two filters. Only diff in stock numbers are the last digit, Seadoo being a "1" and the Can Am "3".
I have one at our shop that I could measure and post up. I won't be over there until the weekend though...
SeaDoo Filter same size as Can Am '14 Filter
Stopped by dealer today and compared SeaDoo 420956741 to Spyder 420956743 and they are IDENTICAL in SIZE with the same grommets on both ends.
Construction of the Seadoo filter is much like the Hiflo used in pre-14's; that is, it does not have the outer wire construction. However, many of us have used Hiflo filters exclusively with no issues that I've heard of.
Therefore I can see no problem with using the Seadoo if you can't find the Spyder one. Priced about $12 vs $16.
Let me point out that I'm not a mechanic, and not proposing that any of you do this. Its strictly your call.
Maybe someone with more knowledge of the 1330 motor and its oil pressure system can chime in on this subject.
I've emailed BRP asking them if the two are interchangeable.
Heres what the Seadoo filter looks like:
http://www.ebay.com/itm/4-STROKE-OIL-FILTER-SKI-DOO-LYNX-SEA-DOO-EVINRUDE-JOHNSON-ROTAX-CAN-AM-420956741-/261222557827?pt=Personal_Watercraft_Parts&hash=ite m3cd213e883&vxp=mtr
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Cool! Looks like the problem is solved. K&N also makes a filter that many seadoo peeps choose.
You all can be assured that if it holds up in a 1500cc supercharged engine putting out 260+ hp with long extended times of running 8k+ rpms, that it will surely hold up in the 1330 motor..... [emoji106]
So I got curious as to my dealership having oil filters in stock since I'm taking my RT in for 3k mile service and some warranty work on Friday (ignition/frunk issue, leaking rear shock).
Service told me they had plenty in stock if I wanted extras since hubby will do all oil changes after this; I could buy the kit or the individual filters and O rings. No problem on the supplies here......
What is the K&N number? KN556? kept popping up while I was researching but it appears to have a closed end so that won't work. Also, I think K&N's are made by Hiflo...or at least some are.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
All K&N oil filters are made by HiFlo. Air filters are made by K&N.
If the physical dimensions are the same, then it should work. The business of regulating the filter is done by the stem that goes through the middle. The filter is the filter, size of the filter media is the only difference that could be. The stem that goes through the middle is old school motorcycle technology and has been in use for somewhere around 40 years or so.
KN556. Open on both ends.
First service completed on 2014 RT L - all parts in stock - YES!
Hello fellow Spyderlovers,
I had my dealer just complete my first service / oil change on my 2014 RT L. I asked when I set it up if there were any issues with parts, and the service manager said no.
He is credible! Just got home after being at the dealer for my first service. No issues whatsoever! NO mention of any parts (i.e. filter) for the oil change in backorder or any other issues.
As a matter of fact, while I was at the dealer, I purchased a complete set of O-rings, washers, filter, etc. for my next oil change -- all in stock.
Are all of you really going to wait the "EVERY 15 000KM (9,300MI) OR 1 YEAR (WHICHEVER COMES FIRST)" to change your oil again???
I think I'll get it on the 5000 mile intervals from now on -- any thoughts?
Happy and safe rydin'
2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
Reply (or Non-Reply) from BRP re' alternate use of SeaDoo Oil Filter
I really expected better of BRP but perhaps my query never got to the technical types. Heres what I asked and following is the classic CYA beaurecratic answer:
"Is there any reason this Seadoo oil filter 420956741 should not be used in a Can Am RT SE6 in place of 420956743? I cannot imagine the 1330 ACE having more oil pressure than the 4-Tec Seadoo motor and requiring the wirebraced filter now being used in the 1330. Thanks"
"In response to your request BRP does not recommend modification to the units. As mentioned in the exclusions of the warranty section of the operator's guide, the following are not covered under the manufacturing warranty;
• Normal wear and tear;
• Routine maintenance items, tune ups, adjustments;
• Damage caused by failure to provide proper maintenance, operation, care, service or storage;
• Damage resulting from removal of parts, improper repairs, service maintenance, modifications, or use of parts or accessories not manufactured or approved by BRP or repairs done by a person that is not an authorized servicing BRP dealer;
• etc;"
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Filters
I have been running EMGO filters on my wifes 2010 RTs since 600mi. service cant believe they don't have a match, quality filters great price
Originally Posted by JLSpyder2012
Jim,
Glad it went well!
I think I am going to do the next one at 9300 miles (6,300 since first one) an maybe send in a sample to have it tested. I will then decide if I go with BPR's change schedule.
Les
PS - we are just outside Bryce Canyon for the night?
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Enjoy and be safe!
Hi Les,
What a great trip! I didn't know you were heading out of Durango heading west....I thought you were coming back after the event. Did you get any ride time with Butch and Paula?
Have fun and safe travels.....
Jim
Kathy and I took this week off as well and decided to try and see all the National Parks in southern Utah.
Temps have ranged from 85 to 105 durring the day so we are taking our time and drinking lots of water. We have not got into a hotel room before 7:00pm and today it was after 8:00pm
Yes we spent all day Thursday riding with Butch and Paula - just the 4 of us. It was great!
The plan is to arrive home Saturday evening.
Les
Originally Posted by akspyderman
Just received two oil change kits that I had to order from our friend Pitbull. They took about a week to get here.
My dealer service department says they are still backordered from the factory until September. He was surprised I was able to come up with mine.
I have noted recently that not much is being stocked here. That includes two tires that I had to wait a week or so for. I have now become pro-active. Not going to bring in for service unless I know they have the parts to complete it.
Will have to see what happens if something of warranty nature happens.
Glad you were able to score what you need. As for warranty doing the oil change when required by the manufacture will keep it covered as compared to waiting for your dealer to do it whenever they get the required oil filters in.
I had the 3000 mile service on my 2014 RTL on Friday, and there was no problem installing a new oil filter.
Make sure you get what you pay for
Have heard that some of the 3000 mile services are only getting the oil changed. Probably nothing wrong with letting the filter go til the next change, but you are paying for something you didn't get.
Unless you have total confidence in your shop, tell them to put the used filter in a zip-lok you provide so you can examine it later.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
