2013 RSS not happy
This is my first post I bought a leftover 2013 rss trailered it home and man im glad I did unloaded it from the trailer started it check engine light on vss light on limp home mode code I think was 1614 had something to do with throttle. It only has 2 miles on it call dealer 100 miles away took a week for them to pickup now still there 2 weeks and 16000 bucks later i still have not ridden it. I have a feeling they will give me a hard time about trailering it back to my home so now I will need to blow a day off work and rent a truck and trailer again because I wont trust driving this anywhere far from home def not 100 miles. It sucks and just my rant because im not a happy camper.
Sucking lemons
That leaves a very bitter taste in your mouth, hope you get it sorted and it brings a few smiles to your face.
Alan:
2013 Spyder ST Limited
TBR Black Series Slip-On Exhaust with M-5 Carbon Canister and P1X power tip and black bolt kit
Fox Podium shocks
BRP Carbon black sports rack & backrest
Custom Dynamics LED converted taillights & black tag bolts
WrapMySpyder carbon dash kit & GT stripes & graphics
Bestem USA carbon side fairings, belt guards & under tail
Procoat NZ powder coated wheels
Hydrographics NZ carbon dipped front suspension covers, billet caps and dash surround
Spyderpops 3D SS Grille set
First guess - discharged battery. Makes for a pretty unhappy spyder. Hope it all gets figured out to your satisfaction and you can put this hiccup behind you!!
That sucks, man sorry but I don't think I'd call it a lemon yet. Most dealers have transport trailers and trucks so Id be on the phone telling them that needs to happen but only after them road testing pretty extensively to make sure its right for ya. Should of been right from the start and not after you got it home and went on the first ride.
Good luck
Bill
2013 RSS Neutron Green
BRP HID's and Fogs
Custom Belt Tension
2014 side panels
HMF Exhaust
K&N air filter
Bajaron sway bar and links
People are really quick to call things lemons on here. One problem on a bike that is basically new isn't a lemon. Most likely, as said above, a battery problem from sitting. Let them fix it.
Thought battery too pluged it in to my charger went to maintance charge within an hour dealer said they charged it and they did. The one thing that was aparent was when started you could crank the throttle all you wanted and it was dead still idled though now before you ask it started and ran no problems when i picked it up. Letting them fix it is not the problem( I just hate the fact i just spent all this money and it needs repaired) the money this is costing me is, it is 2 weeks now and i have not even put the temp tag on it plus the fact I may have to go get it before it is allover with I will have another $1000 into it.
Bummer..!!
know that there is little we can say to make it right. It happened and it leaves a mark. I do hope they get it sorted out and you do get to enjoy it the way it should be. This is the place for help and assistance and therefore makes it seem like there are nothing but problems but not so. These are the very few. Sorry your here for that reason...
2012 RS sm5
When I went to pick up my 2014 RTL they had just finished assembling it
had to wait for tech to put 30 miles on the bike to make sure everything was working correctly
Dealer said this is what BRP wants them to do
Everything was fine and I rode it 250 happy miles home
Have not had ant problems in 6000 miles
Don
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
The code was probably P1614 which is a throttle body code
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Am I missing something, but if this is a 13, why is it not under warranty?
PK
PK
It is under warranty they just live very far from the dealer and he hasn't put a single mile on the Spyder yet.
2010 RT- 622
Hopefully just needs a good charge, then all the systems will not freak out.
Too bad not checked better...as you said...a left over 2013...may have sat around awhile and battery weakened.
18000 ELECTRICAL SYSTEM: SOFTWARE |
Bulletin No: |
SB-2014-0001 |
Date of Bulletin: |
04/09/2014 |
Summary Description: |
BRP: ON SOME MOTORCYCLES, NEED TO HAVE THE FRONT FUSE BOX COVERS REPLACED WITH AN IMPROVED COVER IN PRODUCTION AND ALSO, UPDATE ECM SOFTWARE (P1614, HI TEMP LAMPS, LIMP HOME MODE). *PE |
http://www.spydertechnician.com/dlfi...C%20Update.pdf
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
Originally Posted by mstngken
This is my first post I bought a leftover 2013 rss trailered it home and man im glad I did unloaded it from the trailer started it check engine light on vss light on limp home mode code I think was 1614 had something to do with throttle. It only has 2 miles on it call dealer 100 miles away took a week for them to pickup now still there 2 weeks and 16000 bucks later i still have not ridden this lemon. I have a feeling they will give me a hard time about trailering it back to my home so now I will need to blow a day off work and rent a truck and trailer again because I wont trust driving this anywhere far from home def not 100 miles. It sucks when you get a lemon they have your money and you are stuck with something just my rant because im not a happy camper.
Maybe the nanny got upset loading on the trailer. Sometimes you can take the key out and wait a couple of minutes and try again and it might reset. I've had strange things happen just after having mine on a jack.
Good Luck
2015 RTS Ltd Spyderpops bumpskid, Dual Isci Hand Brake ,Baker Wind Wings
2016 Polaris Slingshot SL
Bulletin No: |
SB-2014-0001 |
Date of Bulletin: |
04/09/2014 |
Ok this is what my dealer called and told me was the issue he said it is fixed and running again they are delivering it today. Now how did it leave the dealership without this update the sevice manager even said the same thing he said someone will get an arse chewing over this because the predelivery check list was all checked off. I am still lost at how this made my throttle not work throttle was dead but bike would still start and idle i am hoping it solved all issues and I can get on the road and put this issue in the pasture.
Did they tell ya anything else they did??? I have not had that up-date done or had the covers replaced, I have had no warning lights come on. Did they say there had been any moisture in the fuse boxes??
Bill
BRP HID's and Fogs
Custom Belt Tension
2014 side panels
HMF Exhaust
K&N air filter
I would try to put a fresh new battery and throw the old battery. Good luck. Check the oil too please.
2012 Spyder RT SE5 Brake pedal mod
The first thing you should do is get a battery tender and keep the battery full charge when the Spyder is not being used. The Spyder is a high tec. machine with a lot computers on board. This is what I used for the last 3 years. http://www.amazon.com/Battery-Tender...Battery+tender
Mike
Mike
I am now keeping it on a charger I have the one by auto meter its called a battery extender I bet made by the same company conections are the same the place where I bought it put the batt tender quick connect on it they said they do this on all the things they sell. The battery is charging fast and the light goes green to show its in maintance charge.
When I took my fuse box covers off when the problem was there yes there was moisture on the covers. If you did not get this done I would take it in and have them do it there is also 2 bolts they replace for the belt guard cover dont know what the importance is there maybe they come loose.
It has happened before some tech who set up a new spyder are the newbies. It did not make it not work but it is fly by wire and the update changed some parameters to make that fault less sensitive. I believe it has to do with the TB sensor feed back. Glad it works now
Many reports of the bolts coming out.
Yeah it will get done but for now it's to nice to put it in can am jail for couple days.
It has seen rain once and hides in the garage the days it not riden.
I did check the chain guard and it is tight . It'll get done eventually
Bill
BRP HID's and Fogs
Custom Belt Tension
2014 side panels
HMF Exhaust
K&N air filter
