I need installation instructions
I bought a used brp trailer hitch, it did not come with the instructions. I need the wiring hook up directions. Please help. Could someone scan them and email me.......randygoodwin8177@att.net.........thanks alot!
Randy
HAPPY SPYDER OWNER
GULF COAST SPYDERRYDERS
you have a fax # i can send them to you
what a great place to get info from great people.
No fax #
HAPPY SPYDER OWNER
hope this helps you
INSTRUCTIONS
- 1- Install hitch ball using Loctite 271 (red) on bolt threads, tighten to specs.
- 2- Install the mud guard using the provided rivets. (4)
- 3- Open top and side storage compartment covers.
- 4- Remove 2 screws on top of each side storage compartment.
- 5- Remove 4 screws on the rear of top storage compartment.
- 6- Remove 3 screws on the upper portion of rear fender, remove fender.
- 7- Detach gas shock retaining each side cover.
- 8- Remove 2 screws on the rear of each side storage compartment.
- 9-Disconnect license plate light connector.
- 10-Remove screws securing the tail light/brake light on the left side.
- 11- Unplug tail light/brake light connector.
- 12- Remove the LH inner fender.
- 13- From the inside of the top storage compartment, remove screws securing the left speaker.
- 14- Open seat and detach gas shock.
- 15- Remove retaining screws from battery access panel, remove panel.
- 16- Disconnect the passenger heated grip switch, the audio input jack (on so equipped models) and the pillion rider switch (PRS).
- 17- Remove screws securing LH passenger's handhold.
- 18- From the rear of vehicle, slide both connectors of (trailer) connection module between the LH side compartment and under tail cover.
- 19- Under seat, disconnect the rear lights connector.
- 20- Connect the (trailer) connection module connectors between previously disconnected connectors.
- 21- Reinstall handhold screws, before tightening to specs, make sure of having a minimum of 15" of harness between (trailer) connection module and under tail cover.
- 22- Reinstall all removed parts except the rear fender.
- 23- To install the (trailer) connection module, three holes must be drilled in the rear fender. Using a step drill, drill one hole 7/32" and one hole 1-5/16". Note: At the bottom of rear fender, on the left side, three marks indicate where to drill holes.
- 24- Install both spring nuts on 9trailer0 connection module.
- 25- Remove the (trailer) connection module protective cap.
- 26-Install the (trailer) connection module in fender. Place wiring harness toward the rear wheel.
- 27- Reinstall the protective cap, install the locking tie through the cap slot. Make sure to position the locking tie as shown in pic.
- 28- Secure the (trailer) connection module using supplied torx screws, secure the locking tie with the external screw.
- 29- Finger tight (trailer) connection module screws. Install rear fender on vehicle, finger tight all retaining screws.
- 30- Clean both ends of the swing arm, apply a thin layer of grease on the inner face of the hitch mounting plates. Not: To avoid problems during hitch installation, the original strap tensioners MUST be installed on the vehicle. Billet parts are not recommended.
- 31-Remove and discard the cotter pin installed on the RH end of rear wheel shaft. Slide hitch on vehicle swing arm until the hitch mounting plates holes are aligned with the center of the rear wheel shaft.
- 32- Note: Pay attention to the brake hose and the sensor wire on the right side of the vehicle. In case of the hose or wire is damaged during hitch installation, hose or wire must be changed before using vehicle.
- 33- Install the supplied flat washer on the retaining shaft and insert the shaft through the LH hitch mounting plate hole. Note; A plastic mallet may be used to insert the shaft. Gently hit the shaft to avoid damaging the shaft threads on the RH hitch mounting plate.
- 34- When shaft threads are visible, install the last supplied flat washer and the supplied castellated nut. Tighten the nut to specified specs.
- 35- Install cotter pin to lock the castellated nut.
