Results 1 to 12 of 12
    Jul 2013
    Iowa
    Default Are My Brakes Worn?
    I have a 2009 RS SE5 with about 24,000 miles on it. Lately I have been getting a brake failure warning when going downhill while applying the brakes. When I level out it goes away. This happened to me last year and I added a little bit of brake fluid to the reservoirs and it went away.
    I am pretty sure the pads are worn to the point the fluid is dropping in the reservoirs just enough to activate the warning. My question is, is there a specification on how thick the remaining material on the pads should be when it is time for replacement? I want to inspect the brakes this weekend and determine if they need to be replaced.
    There is a minimum spec for pad thickness; I THINK that it's 1mm. But you'd better double-check that!
    EDIT: I just checked the manual for my old 2010 RT, and for that bike, 1mm is the minimum. I just don't know if it's the same for your bike.
    Jun 2010
    Las Vegas
    New brake pads are pretty inexpensive and easy to change yourself so for peace of mind why don't you go ahead and change them?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default It's time..!!
    with that mileage I would have new pads on hand. By the time you get to checking the thickness you will have it all apart anyway might as well change them. If you are close and reassemble you will worry about it with every upcoming trip...will they last..?? Will I end up metal on metal and need new disk too..??
    ​2012 RS sm5
    Very Active Member BikerDoc's Avatar
    Clermont, Florida
    thats a lot of miles on a set of brake pads... I would expect them to be shot... like the man says they don't cost much, and of course the life you save may be your own
    220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
    Aug 2007
    Greeneville, TN
    Very likely that your pads are TOAST! You might even be into the rotor on the rear. But that should be making a racket.
    My guess is the warning light has more to do with low fluid in your master cylinder than worn out brake pads (though one does cause the other). That's why the light goes away when you level out.
    I wish Scotty would come back. He used to take care of all these questions for us!
    Active Member revjvegas's Avatar
    Aug 2012
    Houston, TX
    That would be my .02 also.
    check your brake fluid, even a table spoon low can trip that sensor and the min for brake pads is probably the same for all the models, 1mm and I think the disc min is 5.33mm
    Also agree with the last two posters.
    First line of defense, check the level of brake fluid in the brake fluid receptacle.
    At 24K, brake pads are another consideration.
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by Handymandbq View Post
    On my second set by then!!!!
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Very Active Member lyonsden's Avatar
    Dec 2011
    Topeka, Kansas
    I miss Scotty too. Always the mechanical words of wisdom.
    Current: 2018 F3 Limited
    Previous: 2011 RT with 622 Trailer
    Mods:
    F4 Customs 25" Windshield
    F4 Customs Air Wings
    Spyderpops Top Case/Seat Extender
    TackForm Phone Mount
    Lamonster Ram Ball Handlebar Mount
    Show Chrome Passenger Armrests
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by lyonsden View Post
    True! Scotty was always right. I'm only right some of the time. And if you ask my wife.... Hhmmm, on second thought, let's not ask her...
    Very Active Member Sopher's Avatar
    Feb 2008
    Just outside of Boston
    I've been absent for a long time... 5 yrs of daily posts and reads, I've expanding into other obsessions. Ha!
    How do I know if I need new brake pads on my 2010 RTS ? It recently came back from service so they checked and filled fluids. But not inspection of brake pads. When I brake It "mushy" and seems a bit slow to stop.
    How do I measure pads without removing them?
    If they (front or rear) are below the 1mm level, where can I get a set?
    Lastly, anyone have a link on a How to Change brake pads?
    RT-S # 352; Timeless Black... faster than any other color. Mods: EasternBeaver PC8 Fuse Box, 12v digital dashboard display, RearTrunk internal Lights.
    Pioneer XMP3 hardwired, KewlMetal highway foot rests, PolkAudio Speaker upgrades (dxi525 & dxi400), Custom Garmin Nuvi bracket and wiring, Panel Savers, Custom LED array third brake light and rear signal LED's. Custom mud flap lights. Daytime Running Lights (3wattsx6). Heated Corbin seat with 'Lamonster' cut. JBL 400watt Amp,
    Other secret mods.
