What's the criteria for when you have to wait for the computer?
I've got a little more than 1,000 miles on my 2013 spyder ST-Limited now and I cannot quite figure out what makes the spyder decide when you have to wait for the computer and when you don't. Obviously you have to wait and see the warning message the 1st time after sitting for an extended period of time but then when stopping after riding a while it'll start right back up. Is there a X amount of time or is it based off of the warmth of the engine? Just curious if anyone has cracked the code
2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
I think it's one of those random things that BRP engineers sit around on Friday afternoons and just laugh about.
it gives you enough time to think, if i really needed to get out of here fast, I'm a dead man
NO BIKE AT THIS TIME
I am thinking about 3 to 5 minutes. Example: fill up at gas station. Reset trip meter, shut motor off, fill tank. If you are within the time limit, the dash display will light up without having to activate the mode button. If you go over the time limit, you need to go through the boot up, mode button procedure.
Don't know..!!
it seems like it changes. I wonder if there is a set time like 1-15 min. Can it be relative to engine temp the hotter the more or less time....
2012 RS sm5
DAM!!!
Had to get the book out and actually read
and the official answer is any time the switch is shut off for more then 5 minutes it will revert back and you have to hit the mode button to by-pass the safety screen.
2013 spyder operators guide page 26 bottom left corner under start up and shut down
You know stuff.
2014 RTS SE6 White
BajaRon Swaybar
Elka front shocks supplied by Pitbull Power sports.
Aligned By Squared Away
Smooth Spyder belt tensioner
Sprderpops Bump skid
BRP TRI AXSIS Handle bars
Luggage rack
2013 STS SE5 Circuit Yellow. The Jenny Mobile!
It also prevents Spyders being used as a get away vehicles and the bad press that would follow.
Illinois Patriot Guard
Founding member of Woodstock Spyder Ryders
2014 RTS SE6 - White
2010 RT/AC SE5 retired with 26,536 miles
I thought they were advertising them as escape vehicles from the paparazzi. Wonder how many stupid questions the reporters could ask before the warning display pops up
