Trip's Over and the Results Are In - Thanks Again J.T.
We cut the trip short by one day (eight instead of nine) and after getting home and unpacking, I had to run the mileage numbers. With 2225 miles of varying driving, i.e. interstate, gently rolling country roads, steep mountain climbs, high-speed twisty runs, and the gentle cruising of the Blue Ridge Parkway, my average MPG is a whopping 34.27. The highest mileage was 38.89 and the lowest was 30.43.
This is a significant increase in mileage that I can only attribute to J.T.'s breather mod. ..Don
P.S. There is definitely a power increase as well.
Glad to see your back on the road and enjoying your ride.
SpydermanCT
2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
That sounds like some good riding. I can't wait to get back to Maggie Valley again and ride in the mountains.
I should have them back in stock sometime Monday. I see UPS tracking puts them in Poplar Bluff.
JT
I am, too. Thank you for that key bit of advice you provided on that cold January evening that helped me get the project started. ...Don
Is it any louder with this mod installed?
Rewaco RF-1 GT
Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
0-60mph: 5.8 seconds
5 speed sync manual with reverse, mechanical dry clutch.
Front suspension: Trapezoidal fork with center spring
Rear suspension: Independent with Bilstein gas shock absorbers
Brake System: Grimeca calipers, linked ventilated discs, with booster
10.57 gallons
Yes, but it's a sweet sound most of the time.
Air intake noise
Someone posted awhile back that they added a foam ring around the filter to reduce the intake noise. Could not find that post but it seems they did a number of modifications. If anyone has experience with this I would like to hear (no pun intended) the results.
Glad that you had a GREAT time!
