2011 p1174 problem
My shop has mine and two other 2011 RT that have the check engine code of 1174 which is a system lean fuel bank 2. BRP has so far been unable to provide a solution to cure this problem. Has anybody had this problem and what was the fix?
Don't know..!!
we have had several with similar problems and they stem from cracked vaccum hoses. I would think they would have checked this but you never know. Check close, eyeball looks good twist it around and the crack or loose fit will be present...
2012 RS sm5
cracked vacuum hose
Very simple and cheap to replace. Even the ones that look good can have a small crack that allows air in. If the dealer does not have the BRP replacement parts a quick trip to the auto parts store will get you the right amount of hose for under $3. Remove the old ones and cut the hose to length and install by pushing it on the barbs. Replace both at the same time as it takes longer to remove the tupperware than to remove and install the hose.
Thanks, I will tell my shop to replace both of them.
This might be a good time to upgrade to silicon (SP?) lines...
My tech says that there are various vacuum hoses, he is asking which two should be replaced?
Don't mean to be a smarta$$, but wouldn't the tech check ALL the vacuum hoses until he found then replaced the cracked ones? Seems as if he could do the rest of the legwork since the cause of the problem has just been handed to him. Maybe i'm being too hard on the guy...
Do them all.
I would change them all, if one has gone it won't be long before the others need replacing.
Alan:
2013 Spyder ST Limited
TBR Black Series Slip-On Exhaust with M-5 Carbon Canister and P1X power tip and black bolt kit
Fox Podium shocks
BRP Carbon black sports rack & backrest
Custom Dynamics LED converted taillights & black tag bolts
WrapMySpyder carbon dash kit & GT stripes & graphics
Bestem USA carbon side fairings, belt guards & under tail
Procoat NZ powder coated wheels
Hydrographics NZ carbon dipped front suspension covers, billet caps and dash surround
Spyderpops 3D SS Grille set
The two that go to the MAPS sensor. Approx. 3.5 inches long.
Marilyn 2023 RTL Red
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
"common sense will prevail....but we see no sign of that"
Having read all the threads about vacuum hose problems attached to the map sensor I have replaced those "TWO" short hoses with silicone hose. Are there anymore and if so where on a 2010 RTS SE5 ?????
