Page 1 of 2 12 LastLast
Results 1 to 25 of 29
    Active Member ChrisW's Avatar
    Oct 2013
    Fernley, NV
    Default WTB Shorty antenna
    I have a 2014 RTS SE6 and am looking to replace the stock antenna with a shorty antenna, what, where can I get one please
    Invalid Emails
    Jan 2012
    Huntsville, Al.
    Do you lose Reception with a shorty antenna? Why do you want a shorty instead of the standard one? I have often wondered these when this question was asked in the past. I hope I'm not hijacking your thread to much.
    Bill C.
    Active Member chisel_maker's Avatar
    Mar 2012
    Evergreen, CO
    Default Wallmart
    Quote Originally Posted by ChrisW View Post
    Wallmart
    Scosche RMA900 Replacement Car Antenna
    2011 RTS SE5
    Mar 2012
    Evergreen, CO
    Quote Originally Posted by bcoulter19 View Post
    Bill C.
    Reception is just as good.
    Many people have replaced them because they broke the long one. The shorty is very flexable.
    Some just don't like that long whip antenna in the way.
    2011 RTS SE5
    Oct 2013
    Fernley, NV
    Quote Originally Posted by chisel_maker View Post
    Wallmart
    Additional info please, will this be a direct replacment and if so how will I get the old one out and the new one in, I have done this on a car but the Spyder is a bit harder I think.
    Mar 2012
    Evergreen, CO
    Default Install
    Pull off your rubber boot. Unscrew the old antenna. Just screw in the right adaptor from the WalMart Antenna and then the antenna. You don't need the cable from the WalMart antenna. Your rubber boot will fit back on without mod. if you use soppy water.
    2011 RTS SE5
    Active Member DRTSB's Avatar
    Feb 2012
    Ottawa, Canada
    Default Antenna
    I just install these on my 2011 RT LTD
    Reception is great for the CB and radio, you just unscrew the old and screw in the new, I used a little Mono black sealant to waterproof the install
    http://www.customdynamics.com/can_am_spyder_antenna.htm
    Dave
    2011 Spyder RT Limited, drive daily (except when it's snowing)
    2012 Honda Fury VT1300
    1974 850 Norton Commando, drive daily, praying that it keeps running!
    2009 Goldwing GL1800 AD, traded in
    2009 Suzuki M109, (fast bike), traded in
    2011 Nissan Murano SL, S, ride to work
    Wallmart
    A good one, and they work. Used for a while on my 2010 RTS. They cost about $10.
    Active Member Texas's Avatar
    Oct 2013
    Austin, TX
    Default Toyota Prius Antenna
    I get great reception with the shorty antenna from a Toyota Prius. I think it looks a bit more professional than som eof the other ones out there. Also, it is stiff; not flexible, and I think the great reception has something to do with the wire that is wrapped around the outside. See my post on it here:
    http://www.spyderlovers.com/forums/s...n-My-2014-RT-S
    -Texas
    Mar 2014
    palmdale cal
    Default antenna
    I got a short one from pep boys to use on my trip i put a rack on the back long antenna was in the way on my 0214 rts 7 mm open end wrench took off long antenna the boot fit right over with a little soapy water i do not use radio only a ipod for music will put longer one back on after rally i am going to in june but the radio did get same reception as with long antenna.
    Active Member iSpyder's Avatar
    Jun 2012
    Georgia
    Default Antenna: Lefty Loosey?
    Quote Originally Posted by docat5056 View Post
    O.k. dumb question alert
    When you took off your OEM Antenna, was it "lefty loosey?"
    I am using a 7mm open end wrench and it is starting to strip the "nut." Before I really start to bear down on it, I thought I would verify. It may be that whoever (or whatever) tightened it at the factory, over did it...
    -iSpyder
    2014 Spyder RTS - Cognac
    2012 Spyder RTS - Blue (17,700 miles)
    Current Mods:
    BRP Backrest
    ISCI Hand Brake w/ cup holder
    ISCI center screw RAM mount w/ universal holder
    ISCI driver and passenger floorboards
    FZ-1 fuse block
    Powerlet 12-volt socket installed in front speaker grill
    Stebel Nautilus Compact Horn
    Hopnel dash bags and saddle bag nets
    Very Active Member lyonsden's Avatar
    Dec 2011
    Topeka, Kansas
    Quote Originally Posted by iSpyder View Post
    Mine striped and I had to remove the block and put it in a vice and remove it with vice grips. Got it done and I really like the walmart shorty ant better. Much easier to install the cover now.
    Current: 2018 F3 Limited
    Previous: 2011 RT with 622 Trailer
    Mods:
    F4 Customs 25" Windshield
    F4 Customs Air Wings
    Spyderpops Top Case/Seat Extender
    TackForm Phone Mount
    Lamonster Ram Ball Handlebar Mount
    Show Chrome Passenger Armrests
    Oct 2013
    Austin, TX
    Mine had the strongest loctite ever made. I had to bust the antenna off and tap the block for the new antenna. Well worth it though.
    -Texas
    Active Member rlynchtx's Avatar
    Apr 2013
    Dallas, TX
    Default Locktite ++
    Same here. Mine snapped the screw off flush at the base. I put the brass block in a vise on my drill press and carefully drilled out the old screw base (very soft metal). Used a 13/64 bit and it left all the original threads in tact so I didn't have to tap new threads. Walmart Scosche (sp?) antenna came with an adapter that fit the block's threads perfectly. I opened up the boot a little by heating a large bolt and pushing it through the small hole in the boot. It fits the base of the WM antenna nicely.
    Dec 2013
    Indianapolis, IN
    Custom Dynamics Website $19.99
    Active Member Chief-J's Avatar
    Apr 2011
    Fort Belvoir, VA
    Cool Shortee
    I tried the Shortee from Custom Dynamits, didn't work well on my 2011. Went to WalMart purchased a car Shortee for $10.95, works great so far.
    Good luck.
    Nov 2013
    Central Texas
    Wallmart
    How has this antenna worked for you? I got one at Auto Zone, works sort of OK was a bear to install as none of the adapters worked quite right.
    Jun 2014
    Strongsville
    Default Took The Advice
    Mine came off on the highway (including the rubber boot). I took the advice I got on this forum and went to Walmart. One of the two-sided screws fit perfectly. Had to use part of the plastic cover (with a rubber washer that I bought separately) because I didn't have the rubber boot. I think this actually looks better than stock. Not sure how the reception is. You can actually get some FM reception with NO antenna.
    PS Make sure to use some blue Loctite.
    Michael
    You call it a midlife crisis. I call it all the things I wanted to do!
    2010 RT-S SE5
    Mar 2012
    Evergreen, CO
    Quote Originally Posted by oldguyinCT View Post
    Easy install with adapters. I used the riser and one of the adapter screws for a direct fit to the spyder. Your OEM rubber boot will fit over the new antenna with the help of a little soapy water. Works great. I live in the mountains where reception is not always great. This antenna works as well or better then original.
    2011 RTS SE5
    Mar 2012
    Spokane, WA
    Bill C.
    I got a shorty at Walmart as have some others Spyder Riders in may area and I have not lost reception. We ride in some real mountainous areas and shorty does as good as regular on my truck.
    2015 RTSE, Red Pearl, Shorty Antenna, Chrome Rear Rack, Deer Whistles, BajaRon Anti-sway Bar
    Mar 2013
    South East Wisconsin
    Default Installed the popular Wal-Mart
    antenna yesterday. Hardest part was removing the old one. I attempted the 7mm wrench to no avail, landed up cutting the antenna as close to the base as I could and using a deep 3/8" drive 7mm and it was TIGHT, but did come loose. There was blue loc-tite applied from the factory and I reapplied some when I reinstalled. I really like the look, and reception seems to be the same so far.
    Lets ride!!!!
    Oct 2013
    Austin, TX
    I still think that Toyota makes a better looking antenna:
    The Wal Mart one bends too easily (giving it a cheap look), and isn't as short as the Toyota one. I'm sure the Wal Mart one is better than dealing with the stock whip, but the Toyota antenna is more inconspicuous.
    -Texas
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Quote Originally Posted by Texas View Post
    Do you have a part number or link for the Toyota antenna?
    Sent from my SCH-I545 using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Oct 2013
    Austin, TX
    Quote Originally Posted by M109Dreamer View Post
    Post #9 will have what you're looking for.
    -Texas
    Mar 2011
    Jackson, MS
    thanks! [emoji106]
