Key stuck!
Just purchased a new 2014 RTS, got home after 30 miles or so and key will not come out. I know there was a service issue for some and dealer said they checked mine and should not be an issue. I got home, put it in reverse to backup in my driveway. I did shut it off without putting the emergency break on so it screamed at me. I tried to turn it back on so I could set the parking break but would not turn and would not come out. I didn't want to force it out. After some time, I did get it out so like a moron, put it back in to try to start it again. Again, can't turn the key or pull it out. I've had a lifetime of Kawasaki's and Victory's and never had a problem. Frustrated beyond belief. $30,000 and broken an hour later. This is Saturday and dealer can't look at it until Tuesday because they are closed next two days.
Any ideas out there?
Banged Up Member
Just a thought..!!
but if you can spray WD-40 or key graphite around the key and twist and move it about it will lubricate the tumblers and keep it from happening again. When you get the key out spray it and insert it straight in and back out a few times before twisting...good luck..
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Happy ending......
I'm confused......I couldn't do anything with the key.....wife couldn't do anything with the key.....buddy came over and he couldn't do anything and then his Irish wife after a couple cocktails spent two minutes working on it and viola! Luck of the Irish! Out it came and everything seems fine! Pulled it out and put it in and started several times with no issues. Should I risk a long ride tomorrow?! Hell yes! Thanks everybody for letting me bend your ear and wish me luck tomorrow. Happy Mother's Day to you mom's out there!
2018 F3-T
Spyder back side view.jpg So here's my new ride, a 2014 RTS.
Went on my first extended ride today on it and had no problems. Enjoyed it thoroughly and felt fine until I got home then out like a light for an hour!
You should contact your dealer to be sure that you don't need to have your locks replaced. And if you do need them to be replaced, I'd look for a new dealer who doesn't deliver Spyders without checking for needed updates.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
This sure sounds exactly like the problem that should have been addressed already...
Response To Key Stuck.
This post requires you to click the Thanks button to read this content.
IBA #47122
2020 RT Limited Asphalt Grey
key & WD40
Three Things: I have been a locksmith for over 25 years and I have made a living at the beginning with the help of WD40 . It is a alcohol base lubricant, and it is not a friend to lock cylinders.(sorry Gene) The alcohol dissipates and leaves a black gummy residual, worse in cold climates. So works at first but in general not good because of the inner workings of a lock cylinder.
Try and place a finger on the lock cylinder and push in while you pull the key out. Some lock cylinders have a retaining clip and this may help to keep everything aligned.
Another thing to try if that does not work is while pulling the key work it in a up and down motion while pulling (gently) , this works sometimes. If you do get the key out look at the cuts of the key as if they are peaks and valleys . If the peaks are sharp it will keep the key from pulling easily.
Wish you luck
Thank to read?
Totally off topic but this is in the thread.
Why do two of the responses require me to thank the author to be able to read them???
The current rides:
2010 Spyder RT SE5
2007 VTX1800R
1999 Valkyrie Interstate
I was wondering the same thing.
Phil
I may be old, but I got to see all the cool bands.
2011 Spyder RT-AC
Key problem
Originally Posted by akspyderman
Glad to hear you got the key issue solved for the moment. Lamonts advice is good if it happens again and you are no where near the dealer.
I would recommend the dealer give it a good looking over. It is a warranty issue and should be fixed for you at no charge.
In the middle of a 4K ride the key became difficult to remove. A shot of contact cleaner, a few insertions and removals and it worked fine.
