Spyder died!
Spyder died on side of road can't get it into neutral to try and restart
2016 F3 Limited Triple Black
You can start it in gear, if your foot is on the brake pedal...
Try pulling up any active codes, once you get it fired-up!
Won't start even foot on brake
Electrical issue?
Could be battery or electrical connection. My first guess.
You can manually get the bike into neutral by moving a bolt under the bike - instructions in your manual - and your tool kit should have the required tool.
don
Did own: 2008, Red, SE5 - and 2010, Black, RT-S Premiere Edition Number 670
Now Own: 2014 Black RT-S SE6
My '13 won't start unless in neutral. Pushing the brake does not work.
Try rocking the bike back and forth a little and then try neutral again. Works for me.
Dealer coming to pick it up. Needed to go in for service anyway. Guess I'll mowing the lawn today
First problem of any kind.
Chuck hope you and all the others going on the cruise have a great time. Post pics. Esp you in the pinstripe suit
Last week my 2012 RT SE5 was not going into Neutral from 1st gear. I would have to shift into Reverse and then into Neutral. It just won't go into Neutral from 1st gear, but would coming from Reverse. It doesn't do it all the time, so I can live with it until I have my next service in a couple of hundred miles.
Kraig
2012 RT SE5
2010 RT-622 trailer
2013 Triump Bonneville T100
1971 Honda CT70
1972 Honda CT70H
Bummer..!!
well at least you'll be out riding...hope it's a big yard..!! sorry your ryde ended that way. You have a good dealer if they are coming to get it. You should be good to go soon...!!
2012 RS sm5
Dealer picked up my Spyder in about 45 min. from when I called, also drove me home. They will look at it tomorrow. Hope nothing serious!
We get a tool kit????????? wow. new 2014 owner. didnt get tool kit, tire pressure guage or funk light. All I got was a SORRY
Glad your spyder is being taken care of
Look under the seat, the tool kit should be attached to the underside with Velcro straps.
