I got my new sypder home and discovered an oil leak. My dealer is 3.5hrs away. I trailered it home so I didn't see it until a day later. Anybody ever have an oil leak like this. Loose oil drain plug? Mike
Possibly the set screw leak. They have a recall for that.
I would hope that your dealer would have performed the Service Bulletin for the set screw before they delivered your Spyder but maybe they did not
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Dealer should have performed the recalls. Also check that they cleaned up after adding oil to the machine and it is not residue oil. You can call them give them your vin# and see if the recall was done...
Gene and Ilana De Laney Mt. Helix, California
2012 RS sm5
