Dumb Ass Move!
So, I was taking a very enjoyable ride yesterday on country roads in Tennessee and Kentucky. I started smelling something a bit overwhelming and I couldn't put my finger on it. Although, it certainly wasn't the smell of freshly plowed earth or cattle that I had been smelling all day. Lesson 1: If you detect an overwhelming and somewhat mechanical odor it is wise to stop and see if it is your bike making the odor. I didn't. Upon my arrival home I stopped to do my oil check after a long ride as I always do. OMG! Oil was splattered across the left side of my machine, my heart sank. Lesson 2: Many problems look worse than they are. I quickly removed the panel and saw the culprit. On my last oil check I had not secured the dip stick properly. Lesson 3: Make sure when it is important. I inserted the dip stick properly and cranked "Puff" up and let him run for 30 seconds (give or take). Checking the oil I was very relived to see that oil apparently is like blood in that it looks like there is more of it then there usually is. I was able to add a small amount of BRP's finest and my oil level was good to go. I am thanking the bike angels today.
Take solace in knowing you are not the only one that has made a bonehead move like that.
USAF '69-'89 E7
Thailand/Vietnam 1972
Glad you and your spyder are doing well. This is lesson learn to all. thanks for sharing.
Who said that Spyder are not the best machine???????
2012 Spyder RT SE5 Brake pedal mod
The road Gremlins probably loosened it
Do you have a Gremlin bell?
If so that is what scared them away
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
It sure makes a mess don't it. Don't ask how I know.
2018 F3 LIMITED
That wil never happen Bob.
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
SpyderLovers Sponsor
Learn
Remember, if they make it idiot proof, we just make a better idiot!
Joe Meyer
My Mom already made one...
Yup, so long as we're human we'll make a mistake now and then. Just chalk it up as a learning experience. It often just takes these slights lacks in judgement to get us paying better attention later on.
Messy no doubt..!!
But messes can be cleaned up. Glad you had no other damage or side effect. You will forever remember this incident each time you check your oil..
2012 RS sm5
I recently changed my oil and double checked the dipstick. I was just a little paranoid. Glad everything was ok for you.
At least you put the drain plug back in.
2018 F3 S, BRP SS Grill, Spoiler, Attitude Bars, #1 linkage kit, Chopped R Fender, TBR S1R slip On exhaust, Elka Stage 2 R Shock, Shad saddlebags
Cleaning the motor will be your reminder for next time...
Originally Posted by WasWinger
Good thing they can be. Like the time I drained the oil from my Goldwing, moved the drain pan out of the way, put in the new filter, and started pouring in the 4 qts of Amsoil motorcycle oil. It was after I started pouring in the 4th quart I finally saw the huge puddle forming on the floor underneath. I knew instantly I had forgotten to put the oil drain plug back in! That was one $35+ goof! Had to drive 20 miles to get some more oil!
yup A-D-D gotta stay focused did the same thing once on my Jeep. Heard noise while putting the new oil in my case I had the pan under but 4 quarts of Amzoil in the pan of course Amzoil the expensive oil.........lol
Stuff happens!
Don't need to Over it. If I did that for every DAM (dumb ass move) I have made I would have a flatter head than I do. In fact I just made one this weekend when I broke my right hand mirror glass that CanAm doesn't sell (you have to purchase the complete mirror assembly for $200). So yours did not cost more then a little oil and a lot of clean up time.
It is amassing how little oil it takes to make a very big mess! I had a 03 Harley that I had a high performance motor built for it. One day soon after the build I drove home from a 15 mile ride and when I pulled into my garage found oil all down the right side and dripping off the frame with a oil trail leading out to the road. My first thought was my new $7000 motor is trashed, but it was only down a 1/2 qt.
Turned out that the high output motor also put out high crankcase pressure and popped the pressed in dip stick oil plug.
