Page 1 of 2 12 LastLast
Results 1 to 25 of 31
    Active Member Dib52's Avatar
    Mar 2012
    Wylie, Texas
    Default Blew another rear shock
    Took the wife for a 50 mile ride on Friday, but without incident. On the way home, we had to navigate some construction and unfortunately, the temporary roads/crossovers are in terrible shape. As a result, we did some bumping and banging over the imperfections, and I heard it.....bang! Rear shock was either bottoming out or slapping extended. Didn't think much of it at the time, until I woke up on Sat morning, and there I saw it, a puddle of hydraulic fluid right in front of the rear tire. Chalk another rear shock up, this makes 3. Thought of upgrading, but called the dealer and ordered another. The first 2 were on BRP for warranty, this one is on me. Come quick, riding season is here! Any other options out there for the rear?
    2011 Spyder RT A&C SE5
    Mar 2012
    NJ
    RS or RT? What year?
    Mar 2013
    Quote Originally Posted by DrewNJ View Post
    Drew,
    His post list it as a 2011 RT
    2015 F3S , White & Blue
    Mar 2012
    NJ
    Oh, OK. Doesn't show anything reading from my tablet...
    Very Active Member spyderbirds's Avatar
    Apr 2011
    Bowling Green, FL
    Quote Originally Posted by Dib52 View Post
    Elka has one for the rear of the RT but it is pricey... I replaced one stock with stock. About time to replace again.
    May just splurge on the Elka at Spyderfest this year.
    2015 Intense Red Pearl RTS SE6 - Laser Alignment by Precisyon Trac, Tri-Axis handle bars, ? to be determined.
    2014 XLR Viper 305V14 Toyhauler (Home)
    2015 Ram 3500HD Crew Cab
    Former Spyders
    2010 Blue RT A&C SE5 53K plus miles - never left us stranded!
    2013 Pure Magnesium Metallic ST SE5 11K plus miles - never left us stranded!
    The Elka shocks, are always a good choice!
    Jun 2010
    Las Vegas
    I had one break on my 2010 RTS but 3 seems crazy. Do they have any idea what is causing this, other than lousy roads?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Mar 2012
    NJ
    Anyone ever try an RS shock on an RT? From what I understand the RS shock has more damponing. I run an RT airbag on my RS with the stock RS shock . I only have the shock on the second notch and run 15lbs of air when riding solo and only 30lbs when riding 2 up.
    Mar 2012
    Wylie, Texas
    Quote Originally Posted by spyderbirds View Post
    How pricey?? I dropped $106 for another stock one. Really hope this one lasts longer.
    Quote Originally Posted by SpyderAnn01 View Post
    3 is crazy, but like I said before, this is the first one I'm responsible for. Hopefully the dealer will be able to see if there is anything else abnormal causing this. Just gotta wait for the parts.
    It does have me questioning if I'm doing something wrong. Here's another question for the low rent A&C crowd with manual air adjustment on the bag...what psi are you running 2up? I generally have about 80-85 psi in the bag when the co-pilot is on. Without revealing too much about the mrs., we are a combined 435 lbs. Thought I was about right. Solo, I drop the bag to 45psi. So...where's everyone at?
    Default Very pricey..!!
    Depending on the model $600.00 to $1400.00. Progressive has some a bit cheaper like $400.00. Race tech are like elkas. Not much to choose from..be nice to find out whats going on with your...good luck..
    ​2012 RS sm5
    Very Active Member SNOOPY's Avatar
    Aug 2013
    Not to sound rude, but you blow out 2 stock shocks and you order another of the same shock?
    Mar 2012
    Wylie, Texas
    Quote Originally Posted by SNOOPY View Post
    I think the above post sums up why I went stock again. One bad from initial assembly I'll give the benefit of the doubt to BRP, the 2nd blowing out because of roads....I guess it was just that. If the 3rd goes out quickly, then idk!! I did have 10k on the most recent one.
    Aug 2013
    Okay, didn't realize you had 10,000 miles on it. Oops.
    Very Active Member Dudley's Avatar
    Dec 2008
    Jacumba, CA
    What air pressure do you run in the rear?
    2008 GS SE5 in 2008
    Traded at 43,000 miles for a left over
    2010 RT SM5 in 2011
    Traded at 57,000 for a left over
    2014 RTS SE6 in 2015, which has 35,000 miles
    Oct 19th, 2017, totaled 2014 RT while killing a Javaline
    Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
    Never had any breakdown stranded issues.
    Invalid Emails
    Apr 2012
    Canal Winchester, OH
    Default Isn't it unusual to be having this type of problem - repeatedly?
    Am I missing something? I was unaware the stock shocks were a problem? I know there are great after-market shocks, but isn't it unusual to be having this type of problem - repeatedly?
    Mar 2012
    Wylie, Texas
    Quote Originally Posted by Dudley View Post
    When 2 up, combined weight of about 435 lbs, 80-85 psi in the bag.
    Invalid Emails
    Aug 2012
    Coon Rapids, MN
    60-70 with 2 up. load weight(her and I) about 350lbs
    Invalid Emails
    Aug 2012
    Coon Rapids, MN
    Quote Originally Posted by redflasher View Post
    I should mention the pressure leaks away overnight and I have to air up again the next day. I'm dumping it at the dealer as soon as they are back in operation. Winter snow collapsed the roof of service area. Seems a bit slow rebuilding it.
    Mar 2012
    Wylie, Texas
    Check your valve core, might be loose. Mine used to do the same until I tightened the core.
    Very Active Member napper39's Avatar
    Jul 2010
    kansas ottawa
    now this is just what my mec at the dealer said never put over 60 pounds in the air bag,and riding duble only use 50 pounds,or you will blow the air bag.
    Mar 2012
    Wylie, Texas
    Quote Originally Posted by napper39 View Post
    Interesting, as I believe you can take the air bag to 110psi...regardless, the bag isn't the problem, it's the darn shock!
    Oct 2010
    Montreal, Canada
    An Elka Stage 1+R is $549.
    Just an FYI...
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    Quote Originally Posted by Trooper View Post
    Just an FYI...
    Hey john, where ya been hiding?
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
    Apr 2011
    Bowling Green, FL
    Just an FYI...
    How is your stock on these looking for purchase at the fest?
    Former Spyders
    Apr 2011
    Bowling Green, FL
    I also shoot for 85 psi when ryding two up. No leakage or any other problem with the air bag here.
    Former Spyders
