2014 maintenance interval
Just had my 3000 mile maintenance. I was wondering how many of you will go the full 9300 miles before the next oil change. Seems like a lot of miles.
David Kenney
I will already by getting the maintenance at 12300 next month, at 9000 it hasn't used a drop of oil and the oil is still very clear, just showing a little light wear color.. I have no concern about going the full distance.. BRP is so conservative if they say you can go that far its likely you could go much further
220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
Do you use the synthetic blend or the full synthetic.
David Kenney
I plan on using the BRP oil and going the distance.
I will absolutely go the distance before changing oil again.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
If I remember correcly it says 9k miles or once a year with ever is first,still great but you are not supposed to drive it for more then a year without service.
2015 RT White,Tj's Dash mount,Rivco's Duel Flag Holder,SealsFloorBoards(Pups),Custom Dynamics fender lights(R/W)Bajaron's Swaybar & links,Lamonster's LED headlights,lidlox.Wiredux A-arm driving lights(upper&lower)FOBO TPMS system,Spyerpops lighted bumpskid,Foom handgrips. tobor9@me.com
As I see it..!!
If you follow the manual you can't go wrong. If you do they pay... But use your own judgement...an ounce of prevention is worth a pound of cure...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
I'll probably just use a 9,000 mile interval... it's easier to figure out and remember!
Doc, are you going to Spyderfest? If so, how about I bring you a sample kit, fee already paid, so that you can collect a sample of oil when its changed and then mail it to the Lab for analysis. You can benefit by finding out how your motor is faring, as well as finding out how well the oil held up.
In the 998's I found that, depending on brand of oil, the viscosity sheared down to upper 20W/low 30W in as little as 2-3K miles. Really curious how our 1330's will fare but with only 2500 on mine its going to be quite awhile before I get enough miles to have a test done. If interested, PM me where you will be staying and I'll bring a kit.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Sorry after going multiple times and almost getting pneumonia on last years trip, I have decided to take a pass on Spyderfest this year,. Otherwise I would be happy with your offer.
