CODE C1282 brake failure
I have read all the postings on code C1282 I still have the code on 2012 RTS sm5
I have checked
1-brake reservoirs are full
2- all brake pads are more than 3mm
3- the brake sw and brake pressure sw check good
4-parking brake sw checked good
5 -I have changed the brake fluid and bleedded the brakes
6-all brakes and parking brakes work good
7- no leaks of hyd fluid
8-the warning light will not go off
any ideas would appreciated thanks John
Just a wild thought, did you follow the reset process in the Service Manual ??
I am not close to my manual, but there is a sequence of having the key on and then pressing the brake pedal to the first 'click' and further on to the second 'click', and doing something with the key and holding your tongue to the east. I gest, but look in your service manual.
maybe doing the reset will clear this code.
"Wheelchairs....Spyders.........sitting, does NOT mean sitting still"..... Spyder Ryder Floto612
It always helps to put your year and model in you signature so we have a clue about what you are talking about.
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
you need to hook up to buds to do this.
Let's see..!!
You have checked well. The code indicates a pressure problem. You may have to have the code cleared with the buds system. Do make sure the fluid is well filled. It doesn't take much for the system to toss a code. Might double check the lines make sure there is no air in there..good luck..!!
2012 RS sm5
I have checked
Thank you all for your ideas will was able to reset the fault code by following the steps on page 700 and 701 of the service manual I did not need the buds. You guy are awesome.
The 2 switches located directly under your brake reservoir, are normally open switches and activated by a magnet on the bottom of the floats when they get too low. Check to make sure the floats sit just above the channel they sit in. If everything else is ok i would unplug the switches one at a time to see if the failure light goes away and to find which one is the problem. This is usually the root cause of this failure when everything else checks out. These are very easy to get to on an RS but I dont know what you have....
...was able to reset the fault code by following the steps on page 700 and 701 of the service manual...
Could you post those steps?
I'm having the same issue with my '08 GS...
Thanx!
c1282
Originally Posted by Istall
Could you pservicehose steps?
Thanx!
Lps fault c1282 reset
1 turn Ignition switch off
2 wait 30 seconds
3 turn Ignition switch on
4 firmly press brake pedal untill you hear a click from the LPS switch
Note , the 1 click will come from the brake light switch. Continue to strongly press to hear a 2nd click. This one will come from the low pressure switch
Info from page 700 and 701 from service manual
I had the 1282 for many months till it was discovered that the
culprit was one of the rear brake pads was thinner than the other due to crud on the bar it slides on. Not sure what that bar is technically called, but when you buy OEM rears, you get a new one in the kit. Might be worth pulling the pads and checking that bar; if corroded, wire brush it, and put a VERY TINY smear of moly on.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
