What year RT do you have?
If you take a peek in your owner's manual; you should be able to find a description of just what fuse, handles what chore...
I looked in my old 2010 manual, but couldn't find much that was useful...
Thanks Bob
I will when I get home this evening. Just taking a break at work and just thought I'd put the question out here. Oh by they it's a 2012.
Bruce
also check to see if your break lights are hanging up
NO BIKE AT THIS TIME
Originally Posted by WV Spyder Ryder
Thanks Bob
2012... The electrical system should be pretty close to my 2010...
I'll take another run at it for you!
John,
GOOD point!
If your brakelights are sticking "on"; your cruise control will never work...
Check brake light actuator and fuses first. That will save you $250 or so plus labor. Yes, they have to replace the whole unit if you have a bad switch. Mine went out at 26K miles and was not covered under warranty.
How can you tell if the brake light is sticking? How do you correct it?
Sent from my Nexus 7 using Tapatalk
