Pastic Bonding Resin?
Does anyone have a recommendation for a plastic bonding resin that I can use to repair the left rear lower rocker panel? The Spyder slipped off of the floor jack that I had under the main frame member, and when it landed, had cracked the black lower plastic panel. It isn't one of the painted body panels, although I have a couple of cracks on mounting tabs that have happened during other mods and repairs.
Don't know how visible the area you are repairing is but Automotive GOOP has been the most durable glue that I have used for plastic repairs. I've fixed lots of things including the headlight mounting tabs in my $40K truck
The glue is clear but it's not invisible.
2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
Thanks,
I'll look for it. For the most part the cracked area lies behind another surface panel so yes its not an "in your face" type of damage.
SpyderLovers Sponsor
Plastex
This stuff is what the pro's use. Plastex.com
order online. Works great!
Joe Meyer
This is the best stuff I have ever used, watch the video. http://plast-aid.com/
Old school..!!
never found a glue that would hold on a clean crack. The new ones I haven't tried and may work well. I always heated up a piece of fine mesh and let it melt into the pastic. Then covered the patch with JB weld or similar product. Can be a back up plan...
2012 RS sm5
I haven't had any luck getting JB weld to stick to the abs plastics
glue
I've used Gorilla glue on plastic. Put a thin backing plate (plastic or thin metal) on the back of the crack and glue that to the panel. Can't see it and very strong.....hope this helps
Originally Posted by bobbobtar
I have never used it, but may try some. Stu, the tech guy at Wing World magizine mentioned it as a good thing
Oldmanzues
plastic repair.
How about ABS cement? I have a tab that needs repair on one of the side panels.
reviving an old thread with some new information
Here's how the Ninja 250 Riders Club fixes their broken ABS panels. I broke off a tab from the rear panel, so I'm glad to have found this nice little guide to ABS panel repair.
http://faq.ninja250.org/wiki/Plastic...ith_ABS_cement
Myron Wooley
USMC 1975 - 1979
2nd Spyder: Pearl White 2016 Spyder RT Limited, purchased December 18, 2016 with 1 mile
First Spyder: Pearl White 2012 Spyder RT Limited, gone to a good home
I use this stuff. Works great. Even on ABS plastic.
You can some of the fiberglass mesh for wall board joints and this becomes incredibly strong.
http://www.sears.com/devcon-s220-pla...FQFahgoddPgKPg
IBA #47122
2020 RT Limited Asphalt Grey
