Results 1 to 25 of 25
    Active Member vrodrjs's Avatar
    May 2012
    Jacksonville, IL
    Exclamation Dead Spyder need some help.
    Finally got a nice day and I'm not at work. Got the spyder out after a long winter nap and no joy. Turn the key and run switch on and everything sounds and looks normal. Hit the mode button, foot on the brake, hit the start button, electrical sounding pop and everything resets. 2012 RTL
    1. I keep it on a battery tender all winter. Checked the battery 11.7 volts
    2. checked all the relays in the frunk remove and re-seat.
    Any ideas before I try to figure out how to get it to the dealer?
    Thanks,
    Bob
    Current Bikes:
    2018 BMW K1600 B
    2012 Spyder RT LTD - Sold
    2003 HD VRSCA (VROD)
    Very Active Member jwulf74's Avatar
    Jul 2013
    Piedmont, SD (Black Hills)
    at 11.7 volts... sounds like you need a new battery.
    2017 Can Am Commander Limited
    2012 Cadillac CTS-V Black Diamond
    2020 F3 Limited Magma Red (miss the 2011 Viper red)
    2010 RT622 - Black
    Very Active Member SNOOPY's Avatar
    Aug 2013
    Or a good solid charge, not a tender.
    SoFlo
    As said, try another battery, charge and check yours, or just replace it.
    Without a good battery, the electronics and systems may not keep up, which will or could pose as other problems.
    All the best with it.
    PK
    May 2012
    Jacksonville, IL
    I'll try that now.
    Current Bikes:
    2018 BMW K1600 B
    Default Little checking..!!
    you can jump start it and go for a long ryde to charge the battery. Just don't turn it off for a good while. It is the battery but the qyestion now is is it shot or just need charging. They tend to last 3-7 years some beyond some less depending on the electrical add ons abd use. Once charged you can have it tested...good luck..
    ​2012 RS sm5
    Jun 2010
    Las Vegas
    Bob, just ride the VRod instead
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jun 2013
    waukesha wi
    If the battery was at 11.7 volts for a long time it is probably in need of replacement. It may take a full charge but it may not have a lot of storage capacity left.
    May 2012
    Jacksonville, IL
    Quote Originally Posted by SpyderAnn01 View Post
    Low tech Harley started right up.
    So now the rest of the story.....
    I think the battery is just low. I have another charger. I hooked it up long enough to see if that was the problem, that was it. So then I start looking around to try to figure out why the tender didn't keep it up over the winter. Well some dummy unplugged the tender about 3 weeks ago so that he could plug in the charger for his drill. So the spyder has NOT been on the tender for 3 weeks or so. I have a motorcycle charger on it now. Guess we'll see.
    Current Bikes:
    2018 BMW K1600 B
    Very Active Member Larry rt's Avatar
    Jul 2013
    Vestaburg Michigan
    My brother didn't use a tender all winter, started right up.
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by vrodrjs View Post
    I hate that when that dummy gets turned loose in the shop
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Aug 2013
    Quote Originally Posted by Larry rt View Post
    Does he live in south Florida?
    May 2012
    Jacksonville, IL
    Default It lives!!!
    Let it charge since this morning and it started right up. All better now. Thanks for the advice. I've never seen a low battery make things act like the Spyder was acting. I know now thanks to SL. Thanks all.
    Current Bikes:
    2018 BMW K1600 B
    Aug 2013
    Just to to clarify, you charge it w a regular charger right?
    I don't see a tender bringing it back to life.
    Glad you got it fixed.
    These critters are pretty fussy about getting the right amount of juce... A low battery will make all sorts of fault codes pop up to scare you!
    A lot of them will reference the D.P.S., aince it's about the largest single-draw of power on the bike
    .I'm glad to hearthat a good dose of electricty; was all that was needed!
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    Usually with the Spyder, 12.4 is about the lowest charge it will take to start up. @ 12 volts a battery is considered fully discharged. 12.4 is a low charge. 12.9 is good, 13 is better. Below 12 is dead.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    May 2012
    Jacksonville, IL
    Quote Originally Posted by SNOOPY View Post
    It is a motorcycle charger. I think it is 1.5 amp. Once it sees the battery is charge it switches to maintain.
    Current Bikes:
    2018 BMW K1600 B
    May 2012
    Jacksonville, IL
    Quote Originally Posted by bruiser View Post
    That is good to know. I thought a 12 volt battery would be fully charged at 12. Learn something new everyday. Thanks.
    Current Bikes:
    2018 BMW K1600 B
    Aug 2013
    Gotcha
    Aug 2013
    The electronics in today's vehicles like well charged battery's or they start doing freaky things.
    May 2013
    Hollister,Ca.
    If the battery is good,3 weeks of no charging should effect it.
    I have had my Harley and wifes Spyder unplugged for months.They both started easily.
    2011 RT LTD. Pearl White
    May 2012
    Jacksonville, IL
    Quote Originally Posted by Spyder4Tess View Post
    We have this thing here in Illinois called Winter, where we put our Spyders away in the back of the garage and don't ride them for months.
    Current Bikes:
    2018 BMW K1600 B
    Mar 2008
    Allegan, MI
    BRP's spec is 12.7 or higher for a fully charged battery in good condition, several hours after removing from the charger.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Very Active Member StanProff's Avatar
    Jun 2011
    Jonesborough Tennessee
    He's lucky if it was a spyder. I have other two wheelers, some will start after months of being idle without a tender and others need the tender. Some bikes have more electronics running in the background such as the spyder and others don't.
    Happy Spyderlovers
    Jun 2011
    With it running it should be about 14 volts checking it with a meter.
    Happy Spyderlovers
