Sorry, but just below the filler neck is overly full. "Full" is about an inch down. Filling too fast will push over fuel. too. It is a bad design.
For best results insert the nozzle barely into the tank and fill by hand, as slowly as possible...especially nearing the top. Stop when the automatic nozzle clicks off. You can top it off until it clicks off a second time, but no more. This procedure offers no guarantees, but it can save some grief. For the 2013 and prior, if you put in more than 4.5-4.7 gallons right when the fuel light comes on, you are probably overfilling.
It is not only the '13s that have this issue, although it is aggravated on the '13 RTs and STs by the excessive heat which can push over fuel as it expands if the tank is too full.
Canister
You could always consider a canisterectomy and be done with it.
2020 F3 Ltd
Spyderpops Bumpskid
Just picked mine up from the dealer that replaced the evap canister and I was told not to overfill the gas tank. Temps are hovering around 80 today on the ride home and upon pulling it into the garage and shutting it off I noticed an extreme amount of gas vapors pouring out from that vent line under the bike. If you hold your hand close to that vapor stream it is hot enough to burn you, grabbed the thermal gun and I'm getting around 167 degrees at that hose end, and that's venting from the tank!! The gas tank is between 1/4 and a half so it NOT overfilled.
