Elkas question
Do Elka shocks raise the new 2014 RT the way they did on earlier years?
2014 RT Limited Cognac ----- Wraps, skid plate, lights, Elkas
2002 harley ultra classic
2008 hayabusa
I win I finally asked a question that Bob does not know the answer to.
I need to mark this on the calendar, 37,000 + posts and he is finally postless.
2008 hayabusa
The answer to that question is No. They maintains the same static ride height as the stock, unlike the 2010-2012 shocks.
Nuts, the 2014 sits lower than the old 2012 and with the bumpskid you have to be careful going over dips. Don't suppose you could make one a little longer? And not mess up handling.
2008 hayabusa
Well, the front stock shocks are sprung very very weak, so we use stiffer springs with less preload which ensures that the shock does not use its available travel after the slightest bump....so you will be able to save your bumpskid no problem.
Blazing Member
Thanks for the info. I am on my way to getting elkas right now. My 2014 sits 1-1/2 inch higher than my 2010 right now so i am happy with that. The bumpskid I had on the 2010 only kissed a few times in 20,000 miles so i am sure the new one will hit less. But that is what it was made to do, right?
The will be specials on Elka's at Spyderfest and yours truly will be there doing FREE installs and tuning for all.
Sounds good, I'm interesed.....If I can find room to haul the old ones home!
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
You could always ship them.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
I agree the ride and handling is far superior, I was just looking for a little more height for bumpskid clearance and hoping that I could get the same 1" rise on the 2014.
Yes that was a post, just no answer.
2008 hayabusa
Or maybe find someone with a trailer going my way. Last time I shipped a pair off my '11 the cost was about $50. Sorta negates any savings.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
That WAS a post...
I was just waiting to see what the correct answer was; that's all!
My mind still isn't made-up about the 2014 front end... it's way better than the older bikes; I just can't decide if it needs shocks and a bar, or not...
Well, you can try the Elka shocks Spyderfest ! Part of the deal we have going on with Pitbull powersports is " Buy em, try em, like em, keep em" . If you are not satisfied with the performance of the Elka shocks, come back and see me. I will take them off, put back on your stock ones, and give you your money back, no questions asked.
We will have an Elka road course on the fairgrounds where you will get to try them out, or take them out on the road for a spin. Your choice.
Trooper: Installation at Pitbull shop, or in vendor area?
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
In vendor area for front only. If you need to have a rear shock installed, it would be at Pitbull Powersports.
I ordered stage 1+r through my dealer. I have a 2014 rts. After removing the stock shocks I noticed the elkas are shorter by 1-3/4 inches. Is this correct? After installing them the ride height has dropped about the same.Do I have the wrong shocks by mistake?
My friend has the identical shocks on his 2013. We checked the preload adjustment ring and they were the same.
The 2013 and 2014 shocks are the same length. It sounds like you may have a set of 2010-2012 Spyder shocks, which are 1 full inch shorter.
All I find on the web site is older model RT shocks
where are the shocks listed for the 2014 RT
Thanks
Don
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
The stock number on the box is Can-Am Spyder RT/R T-S STOCK E36R. There is a number stamped on the head, HP31946 and HP31947. These are serial numbers? The spring is F5.8x254 (same as my friend's 2013 RT.
Having both is a great combination! As I had them on my 2011 RSS and hope to soon add the Elka's on my 2014 RT with my existing Baja Ron sway bar.
** Loving my 5th Can-Am Spyder since 2007! **
