2014 RT recall
Got a call from my dealer yesterday informing me that our new 2014 RT-S had a "possible" recall. The mechanic wanted to know the numbers on the "little black piece of plastic" that was on the ignition key ring. The recall was for the ignition key not fitting properly or failure to turn, and for directional signals that were blinking at the wrong frequency. After looking I informed him that I had no such piece of plastic and hence asked if he couldn't just use our serial number to see if we were included in this recall. He said his service manager told him to use the numbers on the black plastic. I asked if he would look into why he just couldn't use the serial number (which they have), and he said he would look into it.
We've had no problem with the key turning and the blinkers are blinking, so I'm inclined to wait till my 3,000 mile check up to get more info. Our dealer is a 120 mile round trip .
Has anyone else heard about this recall or know about the "little black piece of plastic"?
Bob & Dee
The plastic they are referring to was attached to the keys via a zip strip. Mine says Spark on one side and 1912 on the other side.
2014 White RTS
Illinois Patriot Guard
Founding member of Woodstock Spyder Ryders
2014 RTS SE6 - White
2010 RT/AC SE5 retired with 26,536 miles
Motorbike Professor
The little plastic tag is delivered on one key ring or the other. If neither of your keys has it, either the dealer or the owner removed it. Our dealer warned us not to loose ours.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
2014 White RTS
Ours is 1750, so when will we find out who is on the recall list?
2020 RTL
"Spark", and "1998" here...
Can somebody find out where we can look up the numbers that go with the affected pieces?
2014 RT S SE6 Cognac. Built on 12/20/13.
2014 VW EOS 2.0 TSI replaced the RT S 5/22/2017
In the automotive world that tag and stamped number indicates the key code for duplicating the key.
SpydermanCT
2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
Maybe we should ask the dealers, if that holds true for these numbers as well...
Yes, the code on that black piece of plastic is your key code, and all the companies I have trained for do not reference that number against the VIN on purpose. On most PDI forms there is a place to hand write it on the form so that there is a record at the selling dealer, but it is often not recorded there (just like most of us don't write it in the owners manual). The only saving grace to this after so many of you have posted your key code here is that with the key using the transponder I can't just get a blank key cut and go steal your byke.
Clifford Fargason
2013 Spyder RTL
2007 Royal Star Venture
Motorbike Professor
That's exactly what this is.
-Scotty
Mine's still in shop...
Bob & Dee
Hi. I was left "stranded" by my brand new 2014 RT-S just over a week ago. I'd only ridden it twice totaling a whopping 175 miles! I stopped for my first fill-up and, at first, the key wouldn't open the latch for the seat. After I pulled the key out and re-inserted it, the key wouldn't turn at all. Despite reinsertions, jiggling, etc., it wouldn't budge. I called the dealership and the fellow said it was a "known issue." Several hours later, a tow truck arrived to take my bike back to the dealership. I've been told they're having to replace the whole ignition assembly. As you might imagine, I'm not a happy camper. I don't recall seeing a piece of black plastic, but it might be the sleeve in which my key fits when it's not being used - I'll look when I get home. Nonetheless, no one ever asked me for a number on it, so I don't know if this is the same issue. The dealership fellow told my husband that there have been four instances of this reported nation wide. I don't know the point at which the company decides to initiate a "recall," but perhaps this is it. I would highly recommend getting your's checked out. Since the 2014 is completely electronic, it won't budge without being turned on. The tow truck fellow had to get creative with dish soap and water to get it to slide onto the trailer. If we'd been in dirt, it would probably still be there! Don't get stranded. Good luck.
My plastic has spark but no number. What am I missing?
David Kenney
It is sometimes hard to see, try getting a bright light on it and looking at an angle.
Clifford Fargason
2013 Spyder RTL
Tried bright light and different angles. No number.
David Kenney
Just checked mine and it has spark on one side and 2036 on the other! I also checked the holders that the extra key fits in and the words Spark appears on both sides of each holder!
Thanks. I almost thru the tab away.
David Kenney
- it is what it is - 2014 Black RT-S - Baja Ron Anti-Sway bar, lots of LEDs, Spyderpops Skid Plate, Twisted Sister HID Driving Lights, Tricled 2nd, 3rd & 4th brake lights, F4 Customs vented windshield, Lamonster highway pegs, Ultimate Tall Boy seat, Utopia backrest
Can someone with contacts at BRP find out what number ranges are affected.
David Kenney
My number is 2092, not included in the recall
I don't think I'd be posting my codes on the internet, , but that's just me
Reason: spelling
....and we're gonna ride, we're gonna ride.....
ride like the one-eyed Jack of Diamonds, with
the devil close behind,.....we're gonna ride....
2008 GS.....PE # 2888
Could somebody PM Steve, and see if he'll post the notice?
While I can't post the actual warranty bulletin (it's not a recall), I can tell you that a very small number of Spyders are affected by it.
This is an example of when it's really better to confirm with your dealer if you're unsure (they will be contacting the folks who have affected vehicles beforehand anyways) as they have the actual bulletin and can quickly verify your key code against it.
