So far I added a hitch and connected the trailer I used to pull behind my Harley's. May not be pretty but sure is functional. My Farkle wish list is getting larger.
You could paint it to nearly match the spyder with some rust oleum colors maybe....maybe not. It could end up looking like a 12 year old put it together.
Dan
2012 Viper Red Rt
upgrades:
Baja Ron's Anti-Sway
Diamond-R Arm Rests
Gloriders
High mount brake light
chrome front fender garnish
Bad Boy Horn
Chrome Deflector Rack
Chrome Scuff Nose Accent
Handlebar Grip Fringe
Gremlin Bells
We'll it is already 10 years old and has served me well. Put some new LED lights on it from Harbor Freight. I have thought about paint, I may have to try it.
Now I know why they call it a Farkle. One simple mod leads to another. I went to add a back rest today and dropped the pivot sleeve. I did have a rag in one hole but not all the holes. So I ended up taking the entire side off looking for the part. Wow!
Now that I have it torn down I am contemplating doing other upgrades. I have foot rests on order that are due tomorrow.
Has anyone installed the fan can? I do have a hot foot problem.
I installed the FanCan on it initially. It solved the hot foot problem for me, but later found out it cooked my wife's leg off and would bellow heat from around the seat.
The only time heat soak ever got me was with the FanCan. I ended up pulling it off and adding the port fin mod instead. I still have the original drawings, if you'd like to see about extending the fin an inch. As it was, I'd get some heat at around 45mph with the shorter fin and none with the longer. Things just looked more OEM with the shorter fin, so I just sped up or slowed down to avoid 45. Mostly sped up.
You'd have to mod the plan with foot pegs and maybe bend the fins to fit, but it may be all you'd need.
Amazing how something so small can replace all that. And now I know what a resonator is.
Makes you wonder why they didn't use that in the first place! With somethings Spyder, it seems BRP was purposely trying to fill space doesn't it? I bet it made a huge difference.
