Results 1 to 12 of 12
    May 2008
    San Antonio, TX
    Question Smells funny breaking in
    Got to take the new 2014 RT-S for a ride this morning in the Texas Hill Country. Sorry northern guys but it was sunny and 73 degrees. Perfect. Got a good 100 mile loop in going the back way up to Medina Lake Dam over to Park Road 37 and back home.
    One thing I've noted as it is breaking in is when I back it into the garage and park it, there is the most unusual new vehicle break in smell I've ever experienced. Not just plastic or metal getting warm for the first time but something else I can't quite put my finger on. Has anyone else noticed this and is it normal for these new Spyders? The 2008 didn't smell like this nor did my BMW.
    Smells "funny"?
    What was Supper like, last evening?
    Jul 2011
    Central VA
    Mine did that also, Tony.
    At first I thought it was the rear brake & rotor but, upon closer sniffing, it seemed to be coming from the muffler.
    After several hundred miles it is no longer noticeable.
    BBQ screwdriver or wrench? Pre-op tool(s) left in the machine are a possibility. Also recommend trying to "sniff" it out if the situation persists. Most motorcycles I bought (non-spyder) did seem to have a break in smell.
    Invalid Emails
    Ormond Beach FL
    Cool 2014 Break in smell
    Could be preservation oils used during the manufacturing phase. Especially since components are made globally now.
    My feeble reaction would be to crank it up with the garage door up and run it and give it a sniff over when it's heating up. Don't forget to raise the door for some fresh air. Bet it proves out to be nothing?
    Registered Users spyder-dude's Avatar
    Sep 2007
    Central Virginia (Staunton,VA)
    Yeah mine had the same smell and now over 3500 miles it doesn't....forget when it stopped smelling
    ** Loving my 5th Can-Am Spyder since 2007! **
    Most of us are just a bit... "over-sensitive" ; when these babies are still all brand-new...
    Give it some time. As long as it doesn't smell like somebody stuffed their leftover lunch in there ; I think that you should be good to go!
    Feb 2014
    Sequim, WA
    Default Yep,
    had the same smell. Suspected the belt rubbing as it smelt like burnt rubber or plastic. Finally took the belt guard off--no rubbing. It is still there. Have only 550 miles on mine.
    Feb 2014
    Florida
    Our 14 RT had a burning smell at first ,but after 1500 miles it as gone.
    Jun 2010
    Las Vegas
    [QUOTE=Bob Ledford;783182]Could be preservation oils used during the manufacturing phase. Especially since components are made globally now.
    My feeble reaction would be to crank it up with the garage door up and run it and give it a sniff over when it's heating up. Don't forget to raise the door for some fresh air. Bet it proves out to be nothing?[/QUOTE
    I heard that the smell was from the manufacturing process like you said and mine went away after a couple thousand miles.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    ...Just point it into the wind, and roll some throttle to it; it'll stop!
    Right, Ann?
    May 2008
    San Antonio, TX
    I did smell a little burnt rubber around the belt but that wasn't everything I'm smelling. I'll keep an eye (and a nose) out for it as it continues to break in.
    Thanks to all
