Results 1 to 8 of 8
Thread: gps
    Jun 2012
    geneva ny
    Default gps
    How much would it cost to have '12 RT wired for GPS? I've heard cost $1,000.
    Jul 2011
    Mitchell, Ontario, Canada
    Default Maybe
    Quote Originally Posted by shoppersal View Post
    If you buy everything from BRP and get the dealer to install yes.
    If you can install it your self or feed food and beer to a mechanically inclined friend you can save a few bucks.
    Or you can get as cheap as getting a $100.00 GPS and mounting it somewhere.
    You have a lot of choices. There are a lot of threads on the topic maybe do some searches.
    2018 F3 LIMITED
    The choice on the amount that it'll cost; entirely yours!
    Very Active Member Wiredux's Avatar
    Aug 2012
    Jacksonville, NC
    Just keep in mind there is a difference between a GPS you have in your car and a motorcycle GPS.
    Active Member gnirtsnod's Avatar
    Nov 2012
    Macon, GA
    Doing it yourself and you already have a Garmin 660 or 665 and cradle? Cost of BRP handlebar mount and the BRP harness. (I think the two cost about $250.)
    Don't have the Garmin and paying the dealer? About $1,000.
    BTW, it is easy to install the mount, cradle, and harness if you are used to getting into your Spyder.
    Linden, CA
    If you have an iPhone you can get the app. GPS Drive and use that for the GPS
    that is what I do and I have used it for 2 or 3 years, it works as well as the Garman
    we have in our car.
    Dave
    Invalid Emails
    Sep 2012
    Clermont Florida
    Cool
    Under $200.00 for a 1495 Garmin Nuv LMT with sun shade and blue tooth,touch screen and phone call opt than all u would need is a ram mount and a 12v power supply. I did mine for under $300.00 and it works great opposed to a $800.00 unit plus mount and power supply,your choise.
    Registered Users NZSpyderRyder's Avatar
    Mar 2014
    Waiuku, New Zealand
    Iphone and TomTom work very well together.
    I have a 2013 ST Limited that comes with the Garmin Zummo as standard, it does everything I want it to including bluetooth to my iPhone so I can make and take calls on the move, you can also insert a micro sim card into it and listen to your favourite music. This is all linked by bluetooth to my Ncom fitted to my Nolan helmet. All three options (satnav, phone and music) work together simultaneously and each one fades the other out when required.
    Alan:
    2013 Spyder ST Limited
    TBR
    Black Series Slip-On Exhaust with M-5 Carbon Canister and P1X power tip and black bolt kit
    Fox Podium shocks
    BRP Carbon black sports rack & backrest
    Custom Dynamics LED converted taillights & black tag bolts
    WrapMySpyder carbon dash kit & GT stripes & graphics
    Bestem USA carbon side fairings, belt guards & under tail
    Procoat NZ powder coated wheels
    Hydrographics NZ carbon dipped front suspension covers, billet caps and dash surround
    Spyderpops 3D SS Grille set
