MC Cruise ARRGGH!!
I love my cruise but it's a bear to calibrate. Anybody got any tricks to make it easier to set up?
What do you mean by calibrate? All you should need to do is get to the speed you want and push down once on the switch.
That part happens after you calibrate it. Battery went dead in my bike about a week ago and caused the cruise to loose it's setting. On the MC Cruise upon extended loss of power to the computer settings you have to reset the sensitivity,speed sensor,throttle pull,clutch disengage,brake engage in a specific order at specific speeds.That is what is the bear.
cruze xontrol
I have a 2010 RT SE 6. All I need to do is fet the RT to 45 or higher and hit the cruze and it works fine. But I must be doing at least 45 mph
What model? I looked on the RT shop manual and I don't see anything on calibrating the cruise control. By the sound of it, you may need BUDS. Maybe someone else can step in. Scotty?
Is this a factory cruise or an aftermarket item?
Sounds different from any Can Am cruise control I know of.
Penny and Rick have owned many motorcycles starting in 1974 with Hondas, then to Suzukis, Gold Wings and ultimately Spyders.
74 Honda 360T (pair); 78 Suzuki GS 1000 (pair); 82 Honda Aspencade; 84 Honda 400; 87 Yamaha 1100; 99 Honda Valkyrie; 01 Suzuki Burgman(triked); 02 Honda GL 1800(triked); 10 Spyder RTSE; 11 Spyder RTSM; 12 Spyder RTSL (pair); 20 Spyder RTL (current)
This is an aftermarket cruise system that people put on their GS/RS Spyders. Pricey, but a good unit.
