Results 1 to 23 of 23
Thread: Balancing beads
    Active Member Black Pig's Avatar
    Glasgow, Scotland
    Default Balancing beads
    Anyone tried these?
    Are they an Aye or a Naw?
    http://www.ebay.co.uk/itm/Tire-Balan...p2054897.l4275
    Feb 2014
    Montrose,Scotland
    Tried them or similar on my Raptor without much success but then the tyres i had on weren't the greatest so they may well work on the Spyder,nae much help mate but might be worth a try if you cant get your wheels balanced
    ....................SCOTLAND...................... ...
    ...............08 GS...................
    Jul 2010
    Las Vegas, NV
    Default Dynabeads
    Have had great luck with Dynabeads. Seems to smooth things out. Anything to make it ride better is worth a try. Our 14 had 12 wheel weights on it! 12! Crazy! JMHO, Joe
    Joe Meyer
    Feb 2014
    Montrose,Scotland
    Dynabeads that's the ones
    Very Active Member spydaman60's Avatar
    May 2012
    sussex, nj and tug hill, ny (west turin)
    try a laser alignment and adjust tire pressures before doing it.
    Registered Users rev.rr's Avatar
    Feb 2014
    Green River,Wyoming United States
    Default beads
    Dyna beads work great in: motorcycles, trucks, RV,s cars, here is one of the web sites:
    http://www.innovativebalancing.com/index.php
    they adjust the balance I had them for the 30 K miles I put on the victory vision. Good for the tire during the life of it.
    Glasgow, Scotland
    Soo, pretty much a thumbs up then.
    How do they in comparison with Ride-on?
    Anyone know?
    Nov 2012
    North Las Vegas, NV
    I'm using Counteract beads in my 2 wheeler www.counteractbalancing.com
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member my3gs's Avatar
    Enid,OK
    Quote Originally Posted by Black Pig View Post
    Anyone know?
    Ride-on has made a vibration at about 39 to 48 not real happy wont do it on the next set of tires. That was the only thang I changed an it has never gone away in 4000+ miles. Only did the front tiers.
    2012 RT Limited. Flag graphics, Lower vader wings LEDs, Lower day runner LEDs, Uper turn signal LEDs, Tip LEDs, Finder strip LEDs, Mud flap running an turn LEDs, Inside morrirs turn LEDs, 3-4 brake LEDs, Blue LEDs top under dash, Cup hollders, Large foot rest, HWY foot rest, K&N air flter, GloRyders with remote, Elka shocks 1+R, Soomthspyder, GoPro Hero3, BRP hitch, Diamond shadow trailer.
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    I use dynabeads in my 2 wheeler. When I change the 2 front tires I will be putting beads in as well. To sporatic on the reviews with Ride On to try.
    Sent from my SCH-I545 using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Registered Users Some Guy's Avatar
    Apr 2009
    Lansing, MI
    I have Dyna Beads in the rear tire of my GS...the dealer put them in without asking me first. Ride On can't be used with Dyna Beads in the tire!
    I have Ride On in all of the rest of my tires (fronts on GS, all 3 on RTS) and I really like that stuff. I haven't had any problems with it.
    Number One: 2008 Yellow GS SM5. I love my Spyder.
    Number Two: 2012 RT-S Limited (the poop colored RT) I still have Number One, but Some Girl made me buy Number Two...
    Very Active Member bodymanpainter's Avatar
    Dec 2009
    Yulee, Florida
    I 've used both on my cruisers and can't tell much difference in the ride but the ride on is easier to use.
    Also the dynabeads can get stuck in your valve stems.
    Toby
    2020 RTL
    Very Active Member SNOOPY's Avatar
    Aug 2013
    Do these beads affect the inside of your wheel or tire from them moving around?
    Dec 2009
    Yulee, Florida
    Quote Originally Posted by SNOOPY View Post
    No.
    2020 RTL
    Aug 2013
    Thanks.
    Nov 2012
    North Las Vegas, NV
    Yes the beads can get stuck in the tire valve, so I just put some air in the tire before checking the pressure to clear the valve. Otherwise very happy with them.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Mar 2011
    Jackson, MS
    I have never had a problem with them but I always make sure the valve is on the bottom half when I ck the pressures.
    Linden, CA
    They never worked for me at all tried them on the Goldwing, my car and the Spyder
    no good
    Dave
    Anyone tried these?
    Aug 2013
    no good
    Dave
    Am I reading this thread wrong or are you the only one that has had issues w/ this product?
    Aug 2007
    Greeneville, TN
    Some swear by the beads, some hate them. Same thing for Ride-On. You always have to wonder about installation (correct amount, correct version, etc.).
    I've tried dynabeads and had no luck (not in my Spyder). I've used Ride-On in all my Spyder tires with very good results. I do get the 'Bump' when I've let my Spyder sit for long periods but it goes away pretty quickly except in cold weather (takes longer).
    I would not discourage anyone on the beads based on my experience because others have had success. I like the added feature of puncture repair with Ride-On.
    One thing about Ride-On. You need to use the car tire version, not the motorcycle tire mix. Makes sense because the Spyder uses car tires, not motorcycle tires. You need to add the correct amount. And Ride-On will only correct for a certain amount of 'Out-of Balance'.
    It's best to have your tires balanced and then add Ride-On for optimum effect. But I've been able to get great balance by just taking the wheel weights off and running Ride-On.
    Glasgow, Scotland
    That was top info Ron, I am having the wheels coated, so I really wanted to take the weights off, so I think I'll go Ride-on, because, I also like the thought of additional puncture protection.
    Some great info guys. cheers all.
    Very Active Member cjackg's Avatar
    Chattanooga TN
    I tried the DynaBeads in my 2012 RT Ltd (when it was new) to fix a constant vibration with no success. A careful tire balance job on the front tires fixed the problem after the beads were removed. Want some free beads?
    Invalid Emails
    Feb 2013
    Castle Rock, Co.
    I have used the ride-on in my fromt tires on the RS its not bad except when its cold takes a little time to worm up. I have ridden 12,000 miles and no problems getting ready to put a new tire on the rear and will use the ride-on in it also. jtpollock
