Results 1 to 23 of 23
    Oct 2007
    Question Best Floorboards?
    Which is the best floorboards for 2013 Spyder RT SM5?
    Apr 2011
    GREENVILLE, SC
    which MODEL....?
    May 2013
    SW MO
    Quote Originally Posted by bjpreston123 View Post
    Like most other things , you pays your money and you takes your chances. The perfect floorboard for one person would be unacceptable to another. That's why there are so many. The best bet is to go to a get together like Spyderfest and check out the vendors floorboards.
    Jun 2010
    Las Vegas
    Your choices may be limited since you have the SM.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    The BEST ones; will be the ones that you buy, after careful consideration of the pros and cons of what's available out there...
    Sorry... it's always got to be your money; your choiice!
    MOgang Member GloryRyders's Avatar
    Mar 2010
    St. Louis Mo.
    with the suggestions that you should make plans to come to Spyderfest and check out all the bikes with floorboards and the vendors that will be their. Nothing like an informed decision and you can probably ryde home after the event with a new farkle!
    Spyder: 2011 RT Limited w/ RT-622 trailer
    Mods: ESI Brightsides, RT Rear Brightsides, HMT Brake Light, Scuff Guards, Utopia Backrest, Chrome, and more Chrome, Pearl White Rear View Mirrors, Rear Fender, and Dashboard, Black Rear Wheel and Belt Assy, SpyderPops Heat Shields & Bump Skid, Elka Stage 1+ Shocks, 2012 SF Graphics, Silver Carbonfiber Dash, Corbin Arm Rests, Baker A.W., BRP Vented WindShield. BR's Sway Bar, Tricled White Halo Lights, BadBoy Air Horn, Spyder Legs Floor Boards
    Invalid Emails
    Sep 2012
    Clermont Florida
    Cool
    I will give you my opinion only as I believe that the ISCI floorboards are superior with HGH quality billit aluminum and mounting hardware, check out the website sight sponcer.
    Mike
    Oct 2007
    Thanks for the advice.
    Sent from my GT-N7100 using Tapatalk
    Jun 2012
    Concord, NC
    How tall are you? That could make a difference.
    You always have the BRP floorboards since you have a 2013. They have a "Breakaway" feature where the board will actually tilt forward if you have to use too much brake.
    Seals are big. they give plenty of room to move around, and one model will actually replace the need for highway pegs.
    Isci are basic.
    Both seals and Isci will bolt on to your existing foot pegs (I believe), so if you have long legs, it may still be an issue. My legs were long enough so that seals really couldn't get my knees in a position to ride comfortably for long periods.
    Rivcos replace the pegs, and drop the floorboards down about 1-2 inches. They do allow me to get my knees into a comfortable position (for me). I used to use my highway pegs quite a bit, now I find I don't need to use them as much.
    It is best to find an event, or gathering, and try some different options out though...
    Jun 2013
    NE South Carolina
    Love my Seal DLX and they make them for a SM5
    Oct 2007
    Thanks. I'm 5' 11" and I do have a problem with them being low enough. Will check out Seal @ Rivcos.
    Active Member klinton's Avatar
    Jan 2013
    louisville ky.
    Default floor Boards
    Inspector gadget has nice boards. Can't go wrong for the money. I have them on mine and I love them.
    minnesota
    Love my Web Boards. He's a site sponsor too.
    Oct 2007
    Are the Web boards low enough to let you stretch your legs?
    minnesota
    Well they are the same height as the original foot pegs, but they are strong enough to put your feet up on top where they bend up in the front, much like a highway peg if you want to stretch out.
    Oct 2007
    I am going to spyder fest next month. Will check them all out. Tks .
    The fact that you've got the SM-5 tranny, may limit your options a bit...
    But; good luck, and happy hunting!
    The SM5 will limit your options. Most of the floorboards are set up with the SE5 in mind. I have Seals on both my 's and like them a lot. One set of Deluxe and a set of Pups.
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    here is a link I put together where you can contact the Vendors from spyderlovers for info if there boards will work for your SM5
    http://www.spyderlovers.com/forums/showthread.php?55172-SMORGASBOARD-OF-FLOORBOARDS-PEGS-AND-FOOTRESTS
    good luck, and let us know in this same thread what you ended up with.
    washington state
    The best floorboards belong to me and I made them from 1/4 inch thick aluminum diamond plate. They are exclusive and nothing like them. I put the most love in making them.
    Apr 2012
    New Hampshire
    Web Boards will have both the original long floorboards as well as a new mini board that fit the SM 5 model 2013... see you at spyderfest
    Quote Originally Posted by jerpinoy View Post
    Apr 2012
    New Hampshire
    Default Web Boards Mini and Full size pics
    Top row shows Mini Boards (one with linex coating) the other with Stainless steel. Notice that highway pegs can be used with this model boards.
    Bottom row shows full size RT web Boards.
    Visit our web site for more details!
