Results 1 to 8 of 8
Thread: Riser
    Feb 2014
    Montrose,Scotland
    Default Riser
    Anyone fitted a bar riser? Is it any easy enough job to do,arrived today so hope to get it fitted sometime over next week
    Feb 2014
    Australia
    I did a Helibar riser convert during the week on my 2012 RSS and it took about 3 hours, easiy to do if you remove all top plastic to find where the wires are zippy tied to the frame,
    so no its not hard, but there are many fine threads in here to show how its all done, just use the search box and type in "handlebar risers" or "helibars" or whatever brand your installing
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default what kind
    of riser are you going to use? the brp riser block is pretty useless, and a severe p. i. a. to install. i removed mine to install e z risers.
    it was fun while it lasted.
    Feb 2014
    Montrose,Scotland
    I assume you mean this one :L Just found instructions on the back on how to fit it so looks fairly easy But for the size of it I can't see it making much difference It only cost about £15 so not too fussed about it
    May 2011
    cincinnati, ohio
    Default it is easy
    getting to it is the hard part. i wouldn't bother with it. there are much easier/better risers. they do however, change the look of the bike. small price to pay for the comfort, in my opinion.
    Feb 2014
    Montrose,Scotland
    Quote Originally Posted by coz View Post
    Dam right it is BRP riser now for sale
    Invalid Emails
    Feb 2014
    In the hills South of Edinburgh, Scotland
    Hi Shane,
    Having done a fair bit of research on this before taking the cop out of just buying an ST, I think you have four options here:
    1. The BRP 1" riser. For- cheap, against- 1"!
    2. Buy and fit ST or RT bars. For- huge change that will save your back/neck, against- how much!!!, might look a bit out of place.
    3. The plethora of bar riser adapters where you clamp on to the existing bars, move your grips/controls up and back and then saw off your original bars. For, cheap, easy, 4" of rise/recline with no re-wiring (easing the zip-ties a bit) or 7" with longer throttle cable, against- you have to saw off your bars, so no going back, a bit drastic?
    4. Hellibars. For- about the same as the BRP in terms of difficulty, but with 4" rise/recline, against- not as cheap £300-350 incl delivery and duty, but reversible if you either change your mind or buy another machine and want to carry them over.
    I hope that helps.
    Eric
    Feb 2014
    Montrose,Scotland
    Yup was looking at those ones you clamp on today on one of the vendor sites,first noticed them on someone else's spyder Coz I think??? neck seems to have eased off a bit last couple rides so just gona go with it for just now,cheers Eric
