What Brand Engine oil do you use
I need to buy some oil to take on a trip with me..don't want to run to dealer to buy overpriced BRP oil. What brand do you all use??
Jonny
Amsoil 5w-40 fully synthetic???
MOgang Member & Monster Member
Originally Posted by Rattigan_Roger
amsoil.
10W-40 synthetic motorcycle oil.
Same here.
I use Amsoil 10W-40 motorcycle oil in my 2011 RS-S. I use Amsoil in everything else I drive to.
Mike
Valvoline 10W40 full synthetic motorcycle oil. I will not use Amsoil for professional ethics reasons.
Valvoline
full synthetic, motorcycle oil. i get it at my local auto zone. filter kits from baja-ron.
it was fun while it lasted.
Overpriced BRP oil? The kit comes all in one box with 5 quarts of oil, filter, and orings/washers for $55. Thats like $7 a quart. The extra oil also comes in handy for top offs and to just have some around....just sayin'.
Sent from my Venue 8 3830 using Tapatalk
BRP XPS full synthetic
Envoyé de mon iPhone à l'aide de Tapatalk
I agree.
I agree. It costs me $60.00 to have the kit delivered to my door.
F3L SE5 Black -- F4 windshield w/wings, Reggie LED headlights, driving lights & Cyclops LED, Ultimate seat, Fox shocks, BajaRon swaybar, Lamont highway centerline pegs & 3rd peg, Lamont belt tensioner, K&N air filter, Baker air wings & cup holder, CanAm hitch.
Originally Posted by Texmac1011
Ditto
Me too
Amsoil and filter kits from Baja Ron.
Bob
Jonny
Royal Purple Synthetic automotive, 10W40.
2008 GS SE5 in 2008
2010 RT SM5 in 2011
Bob
Another happy Baja Ron customer here too.
Bob
I have to say is that Ron is a great guy that runs a great business.
Mike
Mike
I don't think anyone is going to argue with you on that one!
The recommended oil for the 2014 engine is 5W40.
They made the same recommendation on the 08 GS and every one since then. I have used the motorcycle 10w-40 Amsoil since 09.
Castrol 10W40 Motorcycle oil Full Synthetic available at most auto supply stores.
I used Amzoil for awhile but the tech that works at the best dealership in the NW has told me that - if it were him, he recommends sticking to BRP AND forgo the full syn. The semisyn is almost 100% syn, is much less expensive and lasts well at to the recommended change interval. I have changed back to BRP. I may send some out after next change and have it tested.
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
I think you will find with proper used oil analysis that neither of these statements are true. Its been shown that the semisyn BRP oil and most all non synthetics will not maintain viscosity rating for 4600 miles in this or many other engines. If the semi were nearly all full synthetic, its used oil properties would be much closer to that of a full syn. Its not. It breaks down significantly as soon as 1500 miles and is pretty far gone by 3000. Good enough? Maybe but that's not what your tech represented.
There are several name brand API certified full synthetics out there that work very well and hold viscosity for the full change interval.
Larry, do send off a sample. I'd be particularly interested to see how BRP oil fares. I've tested Amsoil, Valvoline Syn, and Castrol Actevo Blend, in my previous '11 RT, and NONE held anywhere near a 40W viscosity at 3000 miles. Like JT said above, 10-40 breaks down fast. It would be great if these engines were certified to use 20-50 like a great many motorcycles as that weight oil does hold up.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
I have seen three oils tested, Amsoil Valvoline and Mobil full-syn motorcycle oil. They all had good reports and that's at over 6,500 miles oil the oil. Usually when viscosity is low in oil in 3,000 miles there is an engine problem. One is excessive blow by or engine is running rich (to much gas) or the engine is not breathing (crankcase vent blocked). These are the big three, but there other things that cam do it. Even BRP Blended oil tested good a 3,000 miles. I use Amsoil it's cheaper, comes to my doorstep, and it's made in the USA. That's IMHO.
Mike
