Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
  1. #26
    Very Active Member Dan_Ashley's Avatar
    May 2013
    Redlands, Ca
    Quote Originally Posted by NorCalBud View Post
    I don't own one of these yet, but I've been researching for a while and think this is what I'm going with. I need mine to take up as little room as possible and this one stands on end. It also doesn't need any other ramps. The tail drops (hence the name) allowing for bottom clearance and easy loading. The only drawback I can see is there is no debris deflector for the front end.
    http://www.droptailtrailers.com/stre...y-trailer.html
    Saw those. My gripe was that I wanted some sort of sand/rock/salt guard on the front.
    Dan
    2012 Viper Red Rt
    upgrades:
    Baja Ron's Anti-Sway
    Diamond-R Arm Rests
    Gloriders
    High mount brake light
    chrome front fender garnish
    Bad Boy Horn
    Chrome Deflector Rack
    Chrome Scuff Nose Accent
    Handlebar Grip Fringe
    Gremlin Bells
  2. #27
    For when the "PowerBall Retirement Plan" finally kicks in...
  3. #28
    Registered Users SpyderDen's Avatar
    Dec 2010
    Space Coast Florida
    Have had two of these. Great choice if you don't go the enclosed route. And they do have a model with a rock guard.
  4. #29
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Quote Originally Posted by stillriding View Post
    I just saw a Droptail at Spyderfest that had a deflector mounted up front. I assumed it was an option.
    That would have been my Droptail trailer if you saw it parked at the Candlewood Suites with the optional Stone Shield.
    Here are couple of Pics of my Spyders on the Trailer.
    Here is a link for the optional Stone Shield - http://www.droptailtrailers.com/shop...shield-91.html
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
  5. #30
    Active Member NorCalBud's Avatar
    Feb 2013
    Northern California
    Default Stone Shield.
    Thanks for the Heads-up on the stone shield. I had no idea that existed. for 3bills, it's definitely gunna end up on my trailer! And I think the Spyder looks great sitting up there!!!
    ~'12 RT Limited, Pearl White~
    BajaRon Anti-sway Bar
    Squared Away Laser Alignment
    Custom Dynamics HMT Brake Light, Front Fender Tips & Kit, Front Mud Flap LEDs, Amber & Red Brightsides, Tri-color Magicflex Channelz
    Lidlox Grip Tip Helmet Locks
    TricLED Mirror Signals, RGB Multi-color Halo Underground Effects Kit, LED Headlights
    Palmer Signs Custom "Captain America" frunk graphics
    Twisted Chrome Pinstripes
    Overland Australian Sheepskin Seat Cover
  6. #31
    Vermont
    Default Straps to Tie down a Trailer
    HI:
    Try using " Tie Down Ratchet Strap" The company name is" Discount Ramps" they have different types. Ebay # 310915970813 This strap REALLY WORKS I used the strap to hold my 2012RTS-SE5 on a Snowmobile trailer.
    Blueknight911 ( mike) by mistake hit a toll booth pole with his trailer with my Spyder on the back of his trailer. And my spyder did not move. The strap is very Strong. The strap was the only thing keeping my spyder on the trailer. Good luck
    Deanna777
  7. #32
    Active Member dadof4's Avatar
    Apr 2010
    Ontario, NY
    This is how I do it. Stone guard up front and jacks to tilt the trailer.
    http://www.spyderlovers.com/forums/s...ilting-Trailer
  8. #33
    Active Member maliamd's Avatar
    Jun 2013
    Asheville NC
    Quote Originally Posted by MikeinGA View Post
    This is a great trailer. http://www.the-ultimate-trailers.com/
    Mike
    We bought the Ultimate Trailer. We have trailered our bike many times with this trailer and it handles beautifully. The best part is no ramps. Just drive it on and off. No problem parking in hotels as long as you take precautions to lock the trailer and bike.
  9. #34
    Active Member smoky's Avatar
    Apr 2012
    Douglasville ga
    Default trailering/towing
    Quote Originally Posted by ggivens View Post
    From your own personal experience what is the best way to tow a Spyder RT limited behind a vehicle? I have a new 2014 and would like to know what is the best type of trailer to use when towing the bike? I want to make sure that I can tightly secure it and not damage the front when riding the bike on or off the trailer. Also are there any parking issues with the bike on a trailer I should be aware of?
    To each is own on this one...but I got my needs fulfilled with a 7' x 10' enclosed trailer with pulldown rear door/ramp and 3,500# axle for $2,200 including state sales tax. I put four one inch D rings in each corner to secure my Spyder from sliding about and it works like a charm...smoky
  10. #35
    Active Member duke50's Avatar
    May 2014
    IL
    Default 6x12trailer
    Let's put it this way; a 6x10 single-axle trailer can do the job...
    But a Vee-nose, enclosed, double-axle 6x12, or even 6x14, with a nice long ramp, will do it even better...
    (Assuming that you've got the vehicle to tow it!)
    There are some very complete instructions right in the owner's manual, on how to secure the bike when trailering...
    I have a hallmark 6x12 enclosed trailer there's only an inch clearance in doorway. Looking for 7x12 trailer now. It worked fine for the harley.
  11. #36
    Active Member lionking's Avatar
    Oct 2010
    Cleveland, Ohio
    Default Towing a trailer
    I have a 7x12 6ft high single axle enclosed v-nose United trailer. Side door, 4 circuit breaker panel, two 110 outlets, and florescent fixtures down the top 10 feet plus 2 12 volt lights. I choose a single axle because it is easier to maneuver with my garden tractor from Sears. I brought it to spyderfest and had Wrapaholic put a Lion on the back ramp. I also put in spyder clamps so that I didn't have to tie down, and screw up the front end ailment. they work great and I'm in and out in minutes.
    www.united-trailers.com
  12. #37
    May 2013
    Redlands, Ca
    This:
    Dan
    2012 Viper Red Rt
    upgrades:
    Diamond-R Arm Rests
    Gloriders
    Bad Boy Horn
    Gremlin Bells
  13. #38
    May 2014
    IL
    Default spyder clamps
    [QUOTE=lionking;810852]I have a 7x12 6ft high single axle enclosed v-nose United trailer. Side door, 4 circuit breaker panel, two 110 outlets, and florescent fixtures down the top 10 feet plus 2 12 volt lights. I choose a single axle because it is easier to maneuver with my garden tractor from Sears. I brought it to spyderfest and had Wrapaholic put a Lion on the back ramp. I also put in spyder clamps so that I didn't have to tie down, and screw up the front end ailment. they work great and I'm in
    Where can a guy pick up a set of spider clamps?
  14. #39
    Jun 2013
    queens ny
    Default bob
    BAD idea...
    Dragging the tail, has all sorts of parts spinning that need lubrication...
    Something that is missing, when the engine isn't running!
    i agree with you about towing it front end off the ground and no lubrication being moved, but what i was thinking is the trailers that U HALL rents and if you remove the drive belt from the rear wheel so that the wheel spins freely than i think it is a done deal for towing
    NO BIKE AT THIS TIME
  15. #40
    happy old fart stillriding's Avatar
    Apr 2010
    Elyria, OH
    ​The system is manufactured and sold by a site sponsor. From the home page, scroll down the sponsors to Super Clamp. Their site also includes videos of the system.
