Results 1 to 15 of 15
    Dec 2011
    Bonita Springs, Florida
    Default Shifting RPM on 2014
    Browsed though the manual, probably missed it, but what RPM should you shift at to get to maximum speed as quickly as possible.
    If you take a look through some of the brochures and videos of the new 1330 triple; you can find the rpm level where it creates it's peak torque output.
    Plan your upshift so that it drops you back right to that rpm level, and you'll be good to go!
    Also asked this question a couple days ago. No replies--so I pulled the question.
    I have also searched high and low through the new manual and can find no reference to suggested shifting rpm's--other than put the in ECO mode and let the indicate when to shift.
    Yes, there is the video that was shown early on about shifting--but IMO--the manual should address the situation.
    Springfield, MO
    I shift around 3K to 5K mostly, 5K+ if I'm banging it.
    Quote Originally Posted by Lamonster View Post
    That is kind of what I thought it would be. Thanks for posting your input.
    Shifting at redline is usually a good way to wring the most out of the bike...
    But only when the upshift drops you back to your torque peak...
    Dec 2011
    Thanks, they should have the redline shown on the tach rather all the way around.
    I've done a little bit of research for ou...
    The bike makes peak horsepower at 7,250 rpm, and it's torque peak happens at 5,000 rpm.
    I'm not sure where redline is; but the rev limiter is supposed to kick-in at 8,100...
    Just find the "sweet spot", where the upshift leaves you at 5,000 rpm in the next gear!
    Thinks out loud
    Apr 2012
    Arrow
    Have looked at Daves for redline. If you stand on the left side of the bike and move your eyes up the redline you'll see a thin white line the redline intersects with at 7500 RPM. Am only guessing that it represents redline. Not easy to see.
    7,500 rpm... Thanks!
    Active Member Nils888's Avatar
    Santa Paula, Ca
    I have had mine at 8200 and have not herd any Rev limiting.
    2014 RTS SE6 White
    BajaRon Swaybar
    Elka front shocks supplied by Pitbull Power sports.
    Aligned By Squared Away
    Smooth Spyder belt tensioner
    Sprderpops Bump skid
    BRP TRI AXSIS Handle bars
    Luggage rack
    2013 STS SE5 Circuit Yellow. The Jenny Mobile!
    Aug 2008
    Oklahoma City
    Default rpm
    By butt says racing shifts should be at 5500to 5700. good old fashion research. Just do it.
    Dec 2011
    Thanks to Bob D. and Jerbear for the responses. I found the white line, took glasses and a hard look but it is there.
    Now; it's time to put some black strips down on the tarmac...
    Alpharetta, GA
    Quote Originally Posted by Alberts46 View Post
    You are thinking too much. Just ride!
