Results 1 to 25 of 29
    Jun 2013
    NE South Carolina
    Default Has anyone tried this tire pressure system
    Bryant, Arkansas
    samewok has that system, PM him and he can tell you about it, i believe he likes it.
    Cruzr Joe
    I MIGHT have one...
    waiting for the bike to slip under them!
    Unauthorized....
    Jun 2013
    NE South Carolina
    I MIGHT have one...
    Unauthorized....
    Like we didn't see THAT coming
    Once they came out with one for spyders... I was powerless to resist!
    Jun 2013
    NE South Carolina
    But it shows an RS on it not RT
    Close enough for government work!
    And I'll let you know what I think of it; once it's on the bike!
    Invalid Emails
    Jan 2012
    Huntsville, Al.
    Talked to the company and they said they will fit all can-am spyders.
    Dec 2011
    Bonita Springs, Florida
    I have had one on my Spyder for two years and also on my Victory. They work very well. I used velcro to mount it where I can see it as you will have trouble hearing the alarm. When you go beyond any of the setting you make it will beep and flash. Also, have not replaced any of the batteries in two years. It uses a triple A on the display and little watch type batteries on the stems that attach to the tires. Also, never had an issue with the stems as they are a little large. Some people say not to use them they throw the tires out of balance, etc. not true in my opinion.
    Jun 2013
    NE South Carolina
    Quote Originally Posted by Pierre-SpyderTV View Post
    I'm looking for one myself......but 200$..... have you seen cheaper versions and can we expect to have bad readings if you pay less then $200 ? Thanks.....
    You get what you pay for. If Brp was selling it it would cost $400 No I have not seen it cheaper anywhere, in fact that is the first Spyder specific system I have seen. Some auto add ons are quite a bit more though.
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    I'm just curious about the nut who put 38 psi in their front tires...
    Jun 2013
    NE South Carolina
    Quote Originally Posted by MarkLawson View Post
    I just think that is the max it will read picture
    Dec 2008
    Syracuse, NY
    Don't forget the metal valve stems.
    Is there something more, that I need to know about this?
    Dec 2012
    Greece
    Yes I use them on bike and trl. Works great. A must buy ...
    Dec 2012
    Greece
    We have them here in Oregon for $150. For three wheel or $275 for 5 wheel system.
    Dec 2012
    Greece
    They are made in BC, Canada. Will get his web site soon he moved to bc, calling him now...
    Dec 2008
    Syracuse, NY
    I can only tell you what has been mentioned before on SL's. Since you are adding weight to the valve stem (probably not much) the manufacturer of this system recommends metal valve stems; on its website, it states that; the rubber valve stems will flex and weaken, supposedly.
    The flexing of the rubber valve stem is the same reason that any extension elbow placed on the rear wheel be removed when not checking the tire pressure.
    Harper, Texas
    These have become fairly common for use with RVs. If these work the same, one of the good things is it will notify you of a slow leak in time for you to do something about it before having an Oh, Crap moment on the freeway.
    Oct 2011
    Jacksonville,Ar
    I have had them for about ywo years. they are in rubber stems with no problem.
    They also have a warning symbol to let you know if the battery is getting weak.
    it will show you the symbol by the tire that is affected.
    15 rt , yes Black
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    I have the 360M3 system from doran. The metal stems that come with the kit did not fit the rims. All i know is Len had a he@@uva time getting metal stems to work.
    The system works fine but isn't cheap.
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
    Aug 2010
    Cloquet Mn
    Here is the one I am looking at from Big Bike Parts, it also has good reviews. http://www.bigbikeparts.com/template...A&GroupGuid=16
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    Looks like the precision might be +- a pound... so it's only good to warn you that you have a flat. The only way I've seen to get the air pressure in the front tires within factory specs of ± 0.25 psig is my Dual Fill.
    JT
    Quote Originally Posted by wyliec View Post
    Thanks!
    I'll weigh them, to see how much additional "poundage", they're adding to the bike...
    Will post the results too!
