Page 1 of 4 1234 LastLast
Results 1 to 25 of 83
Thread: spare key?
    Feb 2014
    Austin, Texas
    Default spare key?
    hello my 09 gs spyder only came with one key
    is it code protected? can it be duplicated?
    Bryant, Arkansas
    Quote Originally Posted by gfd1182 View Post
    simple answer is yes, your dealer can do it but may be a little pricey.
    others on here may have other avenues to get one.
    cruzr Joe
    Feb 2014
    Austin, Texas
    thx for the help!
    Jul 2011
    Mitchell, Ontario, Canada
    Your dealer can cut and program a spare key for $60 or $70. If you lose your only working key it will cost $800 to a $1,000 to fix. So get a spare key made.
    2018 F3 LIMITED
    There WAS a fella in Hawaii that would clone your key onto chipped blanks that he had...
    Maybe $50 bucks or so...
    Active Member Web Runner's Avatar
    May 2013
    Houston, TX
    I have a non-oem spare key that works just great. See the link below:
    http://www.spyderlovers.com/forums/s...l=1#post690082
    2010 Full Moon Silver RS SE5
    Default Here's what you do..!!
    you can order blanks online. Then go to a kwick keys shop and have them clone your key. Many key shops carry the blanks and can do all the work but a little more expensive. Mine ran about $35.00..
    ​2012 RS sm5
    Feb 2014
    Austin, Texas
    I went to my local home depot and they couldn't do it
    has anyone had success with walmart, lowes or any other chain stores?
    Your best bet is a locksmith shop..maybe auto store. It is an aprilla blank...
    Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
    ​2012 RS sm5
    Feb 2014
    Austin, Texas
    Thanks
    Jan 2012
    Menlo, GA. 'Lookout Mountain'
    I bought a bunch of these so I could have a spare to open the trunk.
    I got some extras in case some of my Spyder friends needed one too.
    Feb 2014
    Austin, Texas
    Does the 09 rs have a chip?
    Aug 2007
    Springfield, MO
    Yes, they all have a chip and a 2014 key is different than a 2013 and below, different chip.
    They ALL do...
    Hey Gene!
    Do you have any links where we can get those Apriiia blanks?
    And how are you feeling?
    Idaho
    Quote Originally Posted by Cavman View Post
    Is that an Ilco blank? If so, what's the blank number?
    Ilco's X270 blank works great!
    Jul 2011
    Default Cloneable key part numbers
    Here is the info I have for cloneable keys.
    Ilco/Silca - ZD23RT5
    JMA -
    TP05ZA-9.P
    Blanks without a chip.
    Ilco/Silca - X270 (Grind the corners off for some Spyders)
    Here is a link to a inexpensive seller of blanks.
    http://www.lockpicks.com/aprilia-scotters-transponder-key-rw-zd23rt5-jma.aspx
    I make no recommendation for this seller I have never bought from them.
    2018 F3 LIMITED
    Here's what I have found for a potential source for a chipped key that'll work..
    http://www.motorcyclekeys.com/apriliachipkey.html
    Vermont
    Thanks for the info. Deanna777
    Feb 2014
    Austin, Texas
    Thx for the link, i will be emailing him
    Feb 2014
    Austin, Texas
    JMA -
    TP05ZA-9.P
    If i get the ilco will it be ready to use or do i have to get it programmed?
    Jul 2011
    A clone key does not need to be programmed to the Spyder. It will look no different to the Spyder electronics then the original key. See link for more info.
    http://www.spyderlovers.com/forums/s...ighlight=spare
    2018 F3 LIMITED
    Idaho
    Thanks for the info. What I'm thinking of doing is getting one of those cut and hiding it on the bike somewhere accessible, and then hiding the cloned chip key inside one of the trunks like maybe behind the battery cover, or maybe under the seat under some of the plastic. I can use the non-chip key to get into the trunk and then retrieve the real key to drive with.
    I hid a spare key inside the floorboard on my 'wing and carried a hex key in the unlocked storage pocket. I figured if someone found the hex key and decided to look for the spare key they'd probably be caught by the time they would have found it!
    Of course, there's always the chance one would do the same thing my brother did. He locked his keys inside his pickup at the gas station pump so I had to go to his house and find a spare and take it to him. As soon as he opened the door he remembered there was a spare key behind the bumper!
    I do the same thing... keep a dummy key accessible for when I throw the Spyder key in my jacket pocket...
    ...and then throw my jacket; in the frunk!
    I'm also going to track down a couple of spare "live" keys too!
    Feb 2014
    Austin, Texas
    Angry
    Just ordered a key with chip for my 09 gs, dealer said it would be 25$ to program
    That seemed reasonable to me, key cost me 24$
