laser alignment
Is anyone aware of anybody doing laser alignment in upstate NY
Thanks!!!
Check out Spydercomfort.com, they list 4 dealers in NY for laser alignment.
On spydercomfort.com also check the "independent" link of dealers, as well as the state dealer list. You have a NY independent as well if you'd rather not have this done by a BRP dealer.
2015 Intense Red Pearl RTS SE6 - Laser Alignment by Precisyon Trac, Tri-Axis handle bars, ? to be determined.
2014 XLR Viper 305V14 Toyhauler (Home)
2015 Ram 3500HD Crew Cab
Former Spyders
2010 Blue RT A&C SE5 53K plus miles - never left us stranded!
2013 Pure Magnesium Metallic ST SE5 11K plus miles - never left us stranded!
I've been curious. What all is checked during an alignment on these Spyders, the three settings?
To sum it up in lay mans terms, your belt needs to be tracking correctly, then your front wheels are made to run true in line with rear wheel. Finally the correct amount of toe is set. This is drastically simplified but covers the bases.
Former Spyders
I've aligned Race cars, 18 wheelers and ever RC touring cars. Are there any changes to the caster or camber? Or just drive belt and toe?
Drive belt alignment isn't included in most alignment pricing, but needs to be correct before the laser alignment is done. Toe in/out and relation to the rear wheel alignment is the only adjustment readily available to the spyder front end.
Former Spyders
Cool thanks! My 2013 RSS tracks ok, just darts around on a little on these great South Carolina roads. Most roads have wear/crown in the middle.
Just an FYI I thought our 2010 RT was good, had 27000 miles on front tires and no uneven wear when changed out. The alignment made it track better. Others have had the same results.
Former Spyders
