Page 1 of 4 1234 LastLast
Results 1 to 25 of 98
    Invalid Emails
    Texas
    Default Another 2014 with an oil leak!!!!!!!!!!!!!!!
    30 miles and I read some posts about oil leaking. I go check and sure enough on the right front side, I see oil droplets. So pissed. Taking it to the dealer Monday. Whats causing this? I own a 2014 RTS SE6 vin #570! So flipping pissed!
    By any chance; could you post some pics of where this is happening?
    Invalid Emails
    Texas
    yea, lemme go grab a few pix. I read some other posts, they are saying its the clutch housing screw needing Loctite.
    Invalid Emails
    Texas
    image.jpgimage.jpgimage.jpg..
    Thanks...
    (Calling my dealer on Monday to have them double-check that little beauty...)
    Aug 2010
    Riverside, California
    I just checked and mine has the oil leak as well. Life happens. I have worse things happen.
    Invalid Emails
    Texas
    Quote Originally Posted by stevedfive View Post
    Dealer is closed Monday, guess I wait. Cant believe that BRP doesn't know about this. I mean I have VIN #570 and supposedly they knew about the earlier ones!
    Jun 2013
    queens ny
    Default what they said was
    according to the what was posted b4, the oil needed to be drained than the new locktite was to be done. you wonder if they feel they can pull the screw and stick it right back in with the oil still in the bike, so than it doesn't seal right
    Invalid Emails
    Texas
    Quote Originally Posted by cuznjohn View Post
    not sure, my wife is more pissed than me. I am just glad I caught it early.
    Default They know..!!
    don't know if all the dealers know and do this before delivery. Simple fix for a small leak..hope they are not just waiting for first service to care of it. Seems the best time would be at assembly..jmo
    Invalid Emails
    Texas
    Bryant, Arkansas
    No the oil must be removed and somewhere in the process they have to use a locktite promoter, it also requires some drying time
    Cruzr Joe
    Motorbike Professor
    Mar 2008
    Allegan, MI
    I can understand being unhappy because a new toy is leaking. We all want them to be perfect. I can't really understand the depth of some owner's displeasure or worry, however. Engines have been leaking for a hundred years. As long as it doesn't run the oil so low the oil pressure drops or the engine/transmission malfunctions or is damaged, and as long as the oil doesn't get on the rear tire tread, it can be lived with. BRP knows about it and will fix it. If the setscrew Loctite doesn't cure it, or a new screw doesn't, they will come up with a more thorough procedure or a new fix. Take a deep breath, then let it out slowly.
    Jun 2013
    NE South Carolina
    So that is at least 570 with this possible problem ? What was the build date should be on the left swing arm?
    Coolidge Arizona
    Default add mine to the list
    Quote Originally Posted by SAPD911 View Post
    I have oil leak and coolant leak going in monday
    Bryant, Arkansas
    Quote Originally Posted by NancysToy View Post
    chill out, it is a minor problem that will be fixed, it does not prevent you from riding or anything else, it should be a minor inconvenience at most.
    Cruzr Joe
    Coolidge Arizona
    Cruzr Joe
    It is not a minor inconvenience when the another dealer told me he would not work on it because my vin# doesn't show up on the warranty web site
    The dealer I bought it from will do the work on Monday but he is 250 miles away and it is 15 to 20 degrees out and I will be ridding the bike there
    Also I am calling BRO on Monday to ask them what is up the their warranty program
    What if I was stuck out on the road would they say no and leave me there to freeze
    Not a good way to treat customers
    Bryant, Arkansas
    Quote Originally Posted by garb55 View Post
    I was referring to taking it to a competent dealer to get it corrected. I agree with you that apparently the dealer that refused to do it is not customer oriented.
    good luck and i hope your dealer gets it corrected for you. any improper workings on these or any machine is upsetting, but if your dealer (or any dealer) is smart they can fix this properly the first time and make a better customer out of you.
    Believe me when i say that i was not trying to downplay the frustration of any mechanical problem
    Cruzr Joe
    Jun 2010
    Las Vegas
    VIN # 570 doesn't mean that yours is the 570th made.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member Nils888's Avatar
    Santa Paula, Ca
    541 miles on the spyder. Frame# 351 No leaks yet.
    2014 RTS SE6 White
    BajaRon Swaybar
    Elka front shocks supplied by Pitbull Power sports.
    Aligned By Squared Away
    Smooth Spyder belt tensioner
    Sprderpops Bump skid
    BRP TRI AXSIS Handle bars
    Luggage rack
    2013 STS SE5 Circuit Yellow. The Jenny Mobile!
    Bryant, Arkansas
    Quote Originally Posted by Nils888 View Post
    799 Miles on vin # 330 and no leaks (yet)
    Not all will leak.
    Cruzr Joe
    Invalid Emails
    Jan 2012
    Palm Bay Fl
    Folks,,this is so painless it's not funny, they drain they oil remove screw use loctite and screw away lol.... Think of it this way you get new oil lol, if this is the only thing that people are complaint about its a good thing remember the 13s. Take a deep breathe friends
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Sounds like your original dealer did not correctly register the warranty. You should have signed a warranty registration form when you picked up your Spyder. The dealer must file that with BRP. Phone the original dealer and lean on him to get it registered. Tell him if he doesn't do so he can bring a trailer the 250 miles and pick up your Spyder. Don't talk to the salesman, talk to the dealership owner if possible. It will take some patience to get through this, but it will all be worked out. My dealer neglected to register my warranty and I got an extra four months worth out of the deal, so it isn't always all bad. Don't be surprised if your local dealer is reluctant to work on it, or gives you a hard time. You bypassed him and went 250 miles to buy from someone else. He's not likely to be thrilled.
    Aug 2007
    Greeneville, TN
    Not all will leak.
    Cruzr Joe
    Sounds like a random problem. May be that someone on the assembly line had some bad days. Maybe didn't think they needed to use the locktite promoter or they were not applying enough locktite, who knows.
    No one is saying this is ideal nor is anyone making excuses for BRP. Everyone agrees that every new Spyder should be perfect. Still, the fact is that we know they aren't all going to be perfect.
    On a scale of 1-10, this is about a 1/2 . Once it is fixed you should never have any more issues. Your future is very bright!
    Jun 2009
    Beaverton, Michigan
    Default TRADE IT
    I'll trade you even up
