Results 1 to 10 of 10
Thread: Just in...
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    Default Just in...
    Wheel adapters. Check out the link below.
    http://www.motorcycle-usa.com/730/17...pters-Out.aspx
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Member: Royal Order of Rat Bastards
    Danbury Connecticut
    Sounds like a great idea, but................................
    I thought Mary Poppins (the nanny) gets really crabby if the outside tire diameters aren't matched properly.
    Does this offer more tire selections ?
    IBA #47122
    2020 RT Limited Asphalt Grey
    Default Options..!!
    this does open a lot of options.. As long as you don't get to wild with sizes...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Houston
    With these adaptors, what size and offset wheel would you be looking for to get back to stock location to fit under the fenders?
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Registered Users 3 Wheel Addict's Avatar
    Southwest Ohio
    By spacing the bolt flange out further it would impose incredible stress on the bearings in the front hubs. That's why the front rims have such a he backspacing to keep the load neutral on the bearings.
    Sold my 14 RTS went back to 2 wheels.
    2014 Kawasaki Vaquero SE
    Houston
    No doubt the spacers will require a wheel with MORE back spacing than the stock wheels to get the tire back to its original position. But if the wheels are chosen with backspacing equal to stock plus the thickenss of the spacer, the centerline of the tire will be in the same position as stock and the forces on the bearings will not change.
    That is the missing piece of information. What is the thickness of these adaptors? and what is the back spacing of the stock wheels?
    More options for the adventurous; are always welcome!
    Very Active Member Dan_Ashley's Avatar
    May 2013
    Redlands, Ca
    WHOOOO---HOOOO!!!!!
    Now I can put 40" Mudders on my trike!!!!!!
    Dan
    2012 Viper Red Rt
    upgrades:
    Baja Ron's Anti-Sway
    Diamond-R Arm Rests
    Gloriders
    High mount brake light
    chrome front fender garnish
    Bad Boy Horn
    Chrome Deflector Rack
    Chrome Scuff Nose Accent
    Handlebar Grip Fringe
    Gremlin Bells
    Registered Users flybuddy's Avatar
    May 2012
    Fort Myers
    Looked up pricing, all I could find is C&S selling these on ebay for $395. Having purchased various sets of quality aluminum adapters in past, this seems to be awfully high. They don't give adapter width but based on the pics showing lug vs width, these appear quite wide requiring rim choices with a large offset. Since you can run larger tires on current rims, the best benefit of adapters is a wide choice of rims. Nice rims + expensive adapters equals big bucks coupled with test piloting a different size track if you don't perfectly match offset vs adapter width.
    2012 Spyder RT
    Houston
    Yes the adaptors are expensive but would still like some dimensions so can see if any viable options really do open up using these vs the limited choices provided by BRP.
    No one seems to know the backspacing of the stock 2013 wheels or the thickness of these adaptors. I did contact C&S and they were less than forthcoming on information, Trying to sell me one of their wide wheel kits ($10k) or sets of wheels and adaptors etc. I just want the data so I can see what wheels become options with these adaptors. With all the secrecy, its beginning to look like NONE. Just another vendor farce being sold with smoke and mirrors.
    Also, while expensive, no one else seems to offer the adaptors for the 3 bolt BRP hubs.
