Baker Built Belt Stabilizer Guarantees
I have the Baker Built Belt Stabilizer and I LOVE it! Easy installation and works just as advertised.
Thanks for a GREAT product!!!
KYSPYDER
Thanks for the info I am looking into one of these.
There is a reason OEM belt tensioners used on automotive and equipment applications do not use gas spring rods. The continuous motion is not what the rods are designed for and will wear quickly. Belt tensioners are a rotary spring, sometimes also molded with rubber with the spring to dampen but its a coil spring on an arm with the pulley on the arm. There is good reason standard SAE designs are done this way.
I totally disagree with your logic. The OEM belt tensioners used on automotive & equipment applications is to keep the Belts tight. The Belt Stabilizer is not designed to keep the belt tight but to stop the belt from causing vibrations. Two totally different Applications. Shock absorbers on cars last from 50,000 to 100,000 miles so it should be no different on the Gas Springs on our Belt Stabilizers. Also they are very inexpensive to replace if they should ever wear out.
Bruce
First, since the item is a single roller applying force in only one direction, it is by definition adding tension to the belt. A belt tensioner not vibration absorber which would need to absorb energy in 2 directions. It does remove oscillations in the belt by decreasing the unsupported length of the belt, thus raising the harmonic frequency of the belt well above operating range.
Gas springs have o-ring seals and are quite susceptible to dirt on the polished rod. They are also not intended but for a few thousand cycles. Automotive shock absorbers are built entirely different with wiper type seals and lubricated o-rings behind and are designed for many millions of cycles.
I am not making this stuff up. The belt tensioner designs are all SAE standards and the reason they look nearly identical across almost every OEM application.
Folks can buy what they want but why try to reinvent and trouble shoot the wheel?
Belt Stabilizer Gas Springs are Quality Made
All our production Gas Shocks have and added Rod Wipers as seen in the photo below. Our gas Shocks have a built in oil Supply that lubricates the O-ring seal as long as the Gas Shock is installed with the rod end pointed Down. We have had to replace 3 Gas Shocks because they were installed with the rod end up which didn’t allow the seal to be lubricated from the Built in Oil Supply. We have not had to replace any when they were installed properly and they are American Made.
I see no Reason these should not last as long as Automotive Shocks.
Note: Let’s hear from our Customers their satisfaction rating and how many miles on their Belt Stabilizers?
Free Shipping!!
If you place a Order before December 2nd your Belt Stabilizer will ship for FREE.
We hope you have a Happy Thanksgiving!
-Bruce Baker
Gotta say..!!
Durability will fall in that "too many variables" catagory. Don't know how long your product has been on the market so the true results will have to wait a bit. So far seems to be doing well. I have the other one so I have to go on what I have heard...do feel the coil spring has a quicker responce...jmo..good luck on your promotions, they are great offers..!!
If the shock wears out,can a person buy just the shock,or do you have to buy the complete tensioner?..I asked this last august in another one of your threads,but I have not received an answer yet...I know you get a lot of questions..Thanks!
Your best bet to get an answer would be to contact the manufacturer/vendor directly.
Post #5 states the shock is american made and could be replaced seperatly if needed.
Yes folks will buy what they want. I'm not sure this is the place to speculate that a vendors design is wrong. This is a pretty vocal group and I've not seen where someone has been unhappy with the product so far. If everyone just accepted that what we have is as good as it can possibly get and can't be improved on this would be called the Horse and Buggy Lovers site. Anything and everything can always be improved.
There is a great deal you do not get to read about on this forum. My comments were not 'speculation' but facts presented from my and others experience in the automotive and commercial equipment fields. take what you want and leave what you don't
Talk is cheap. If this is truly an inferior product lets see the facts. I'm not concerned with automotive type belt tensioners and he doesn't sell this as one.
sorry we missed your comment on a previous post, we do have replacement shocks if one were to ever wear out. We offer all replacement parts to our customers for any product we have.
I appreciate your comments about the Belt Tensioner. I agree about the coil spring being quicker to response but this is not what is needed. A product that is slow to react will do a better job of reducing vibrations than a product that is quick to react. Belt induced vibrations are a high frequency problem and as a result a product that is slow to react will do a better job of solving the vibration problem.
Example #1- a good quality shock absorber on a car is slow reacting not fast reacting.
Example #2- if the shocks on your car are worn out, your car will continue to rebound.
Sincerely
Bruce L Baker
Sincerely
Bruce L Baker
A device can only dampen if it controls motion in both directions. The tensioner in question does not do that. It does not dampen, it tensions and reduces the unsupported length of the belt thus raising the harmonic frequency above the operating range. Slow response only means the belt moves faster than the tensioner and thus only tensions part of the time. IE the belt unloads the tensioner pulley when it fails to track the belt's movement.
I do appreciate the pros and cons comments on this topic. R & D and time will tell.
Facts always support the best .
Belt Stabilizer Test Results
We are running these comparison test with Rear Wheel Jacked up so that it isn't touching the ground. The Front wheels are both blocked in front & back. The Spyder is run thru the Gears as if it were being driven down the road with the throttle being operated from low to high in each Gear with with speeds up to 60mph.
We made every effort to keep the same pace in both tests. Both with and without the use of the Belt Stabilizer.
With the Belt Stabilizer installed the belt up & down movement was kept to within 1/8"
Without the Belt Stabilizer pulley installed the Belt up and down movement was at least 3/4" or more with considerable flapping in the process. This is what causes the vibrations that you feel while riding down the road.
These test Comparisons show why the Belt Stabilizers are so effective at reducing Belt Vibrations.
The first Video is with The Baker Built Stabilizer
The second Video is without the Belt Stabilizer pulley Installed
Note:We have extended the Free Shipping special up thru Christmas. So order yours now to take advantage of the free shipping and our special winter pricing of just $185.00
God Bless & Have a Merry Christmas!
Ok jcthorne, your turn. Show me that you are not speculating that this product does not or can not or will not work.
stabilizer
looks like it works--think i'll just have to order one !!
