Results 1 to 25 of 29
Thread: Tire Options
    Houston, Texas
    Default Tire Options
    Does anybody have any knowledge/experience with rear tires, I am burning thru them like crazy, how many miles should you be getting from rear tire...
    Do they make other tires that are better than the ones you buy from the dealership....I think I have less then 5K miles on rear tire and it is gone
    May 2012
    Fort Myers
    Quote Originally Posted by Nudels2u75 View Post
    Do a search and you'll find an endless amount of opinions on this subject. The stock tire is too soft and eggs out toward the center at high speeds (regardless of pressure) causing premature wear. There are several car tire options out there. Toyo Proxes, Kumho and Falken. The car tires are smoother and give better wear. There are some available is exact same size, if you change sizes check that the diameter is close. There's almost no one who has switched to a car tire that is disappointed. Some (that haven't), argue that OEM is best. IMO, the main reason the Kendra is used is financial.
    I have a Toyo on the rear of mine and just last week, I swapped out the fronts to General Altima in a larger size 185/60R14. Huge difference in grip and smoothness. I'll never go back.
    MOgang Member
    Mar 2012
    Cuba, MO
    Default Tires
    What flybuddy said is correct. Lots of options. A search will get you a lot of opinions and some good info.
    Here is a helpful bit of info.
    http://www.spyderlovers.com/forums/s...ire+size+chart
    I'm going to be replacing my front tires with Kumho Solus KR21. They seem to be a popular brand. When I change out the rear tire (again) I'll go for a Kumho also.
    Jun 2013
    north carolina
    Default Just switched rear tire
    Just replaced my rear with the toyo yesterday. What a difference. Ride was smoother and cornering was definitely better.
    Jun 2011
    Near Lexington, NC
    Nudel: I'm getting exc wear on the Pirelli P4. Over 10K and lots or tread left. I'm guessing at least 15K or more.
    OEM was good for 10K, General Altimax would have gone more tho I changed it at 10K also.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Southwest Ohio
    I can't even get 1000 miles out of Kenda's on my "other" trike (see pic) and I'm the motor on it! When my stock tires are shot on my Spyder it will be a Kumho on the rear for sure, even ran that tire on my Goldwing. (darkside rider)
    Aug 2013
    Quebec City, Quebec
    For the rear, Khumo, Toyo or Falken. In front, Bridgestone Potenza RE92 for standard size or choose 175/65-R14 size.
    Houston, Texas
    Default Who will install these other Name Brand tires
    Does the dealership install these other tires...
    Anybody having any luck with other chains replacing these tires material and labor
    Discount tires, National tires ....I did not want to have to pull the wheel as I am living out of my Travel Trailer working out of town..
    Teddys favorite human
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Thumbs up You have MANY MANY Options..... and Most are Better than OEM
    We have these all around (different size of course for the rear) and switched the size in front a bit larger and they fill the fenders out nicely. The larger size fronts also made our Speedo spot on to match our GPS, as most Spyders are actually a mile or two over indicated on the Speedo.
    We did this a bit over 20 thousand miles ago, and they are still look'n new
    These pics are when they were put on new when we had 22 thousand miles on Teds Red Sled
    And this pic was taken a couple of days ago, & we're now sitting right under 44 thousand Miles of Smiles
    and the rear is looking just as good
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    Take a look at this link for more rear tire information you might find helpful:
    http://www.spyderlovers.com/forums/s...ction-Evidence
    Aug 2013
    Quebec City, Quebec
    Here in Quebec City, my dealer install these other brand tire. You can also bring your tires at the dealer shop.
    How about aftermarket 15" tires for the front...
    Has anybody done any digging to see what's available out there yet?
    Houston, Texas
    Default How much trouble to take rear tire off myself
    I found the Tire Kumho 225/60R 15 but they will not remove it it...I will have to bring it in....The spyder dealership in Houston I do not care to use, not even sure if they will mount aftermarket tire....
    Is this the correct tire to mount on Stock 2012 Limited?
    I usually get 13K to 15K out of a rear tire on the . My dealer will not install aftermarket tires so I am locked into the OEM's. My experience with OEM's covers 6 rear tires now. 5K on a rear tire seems a bit low for me--unless you are somewhat of an agressive driver.
    Jan 2012
    Menlo, GA. 'Lookout Mountain'
    He didn't say what model Spyder he was driving?
    I have the Brigstone Potenza's on the front and am happy with them. One of my orginal tires had a high spot so I changed them out and got rid of the Elvis Syndrome after 15 months!
    I have over 18K miles on the orginal rear tire. I'm going with a Kendra soon when I get my Spyder back.
    There very few rear tires in the size needed for our Spyders available.
    Houston, Texas
    Default Stock 2012 Limited
    What is the widest rear Kumho Tire that I can have installed and how difficult is it to take tire off of spyder and bring down to have mounted and then re-install...
    Any special tools needed, any special tips or tricks to changing tire out....
    Southwest Ohio
    Actually I'm finding the opposite in that case, I have found quite a few for the rear and only 1 for the front in the 15 inch and that is a Federal tire. I can not find anything else to match that factory size of 165/55-15. I have my own tire changing equipment here in the shop and the metric "peel-n-stick" weights coming in soon then I will be able to mount and balance Spyder tires. I don't think my dealer would mount anything that is not factory cause I had that problem when trying to put a car tire on the rear of a Goldwing.
    Aug 2013
    Quebec City, Quebec
    May be more choice in the 175/55-r15....
    Dec 2008
    Jacumba, CA
    I can easily get 10,000 on an OEM. In the end it depends on your driving habits, hard surface condition of the roads, air pressure, etc.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    What exactly are you trying to accomplish?
    With all of the electronics that monitor just about every functional system on these bikes; you're liable to just end up kicking over the hornet's nest...
    Apr 2011
    GREENVILLE, SC
    Default KUMHO
    KUMHO AST..... KUMHO KUMHO KUMHO for the bizzillionth time.... 225/50R 15...
    I got 27,000 miles from my last one, and they only cost about $80....
    ..And in the stock size; no less!
    Default tires
    Dear Nudels.........there are approximately 2000 posts on tires give or take 100 or so........Do an advanced search ......then if you DON"T find what you are looking for ASK this question again............................................. .................................................. .................................................. .................................................. ...................... Mike
    Default FRONT TIRES
    Are you for real Bob, or did you Post this just to ADD to your TOTAL............. Mike
