RS Parking Brake
Does anyone know if someone makes an electric parking brake kit for an 08 RS?
Not that I know of..!!
why..?? I made an extension and the sell them from suppliers on home page if your problem is it is hard to reach. Maybe some does know of someone that does..good luck..!!
Help with brake!!!
My problem is that it is hard to get to and my foot will flip off sometimes and cause my leg to hit my peg which doesn't feel good at all. I will engage/disengage the brake while off the bike if at all possible but there's times when you can't do this, such as when parking on a hill. Just looking for help in what others may have done to help this problem. Thanks!!!
not that I know of, for replacement parts, but leave it in gear when you turn it off vice in neutral. the transmission will stop the bike while you get off and give you a chance to set the brake.
It will help to keep it properly adjusted. It should lock within 1-3 clicks. There are also some parking brake extension pedals on the aftermarket, if I am not mistaken. I don't remember who, maybe ISCI? The early 2008 pedals were longer, and easier to get to.
I had that problem with my 09 which is the same design as yours. I have trouble with my left leg and lousy ankle control. I made an extension for the pedal pad so I could get my foot firmly planted on the pedal. That worked very well. I believe there vendors that make a pedal extension now, but I made my own with a piece of flat bar. Sorry I have no pics and I traded it off.
I found this pic on another forum and looks almost exactly what I did.
We do still make parking brake extensions for the RS. You can check them out at www.isciride.com under the RS section.
Parking Brake
Hi,
I have the same problem and I just have pay attention if I'm on my bike. 2112 RS SE-5.
I had hit my skin 3 times and had it so messed up that I had to go to my Dr. I did find that If I take my foot off the brake, set the parking brake ASAP that it will catch the first time.
I knew I had seen this before..This link is for an elevated handle for the RS parking brake that one of our enabled Spyderlovers came up with out of necessity and sheer ingenuity...http://www.spyderlovers.com/forums/s...435#post719435
