Page 1 of 5 12345 LastLast
Results 1 to 25 of 124
    Jun 2013
    Default Potential to Make Some Money - Ram Air Scoops
    I suspect someone could make a ton of cash from 2013 RT and RS owners if they marketed an affordable and easily installed air scoop that would fit the grills under the rearview mirrors! Vertika makes one, but it is way too expensive.
    Senior MOMENTS Member
    Sep 2012
    Salem, Oregon! BUDDAH'S Country
    Default Air Scoops
    Have you priced flat plastic lately?
    Then tried to shape it?
    Most of these plastic MODS you see on our Roadsters are either mold injected or heat vacuum over a formed mold. These forms take time and are often tweaked to get them just right. Then you have to look at the failure rate of the product as it comes out of the mold. Last of all is the quantity of finished products you have to have to make it worth while to produce for the projected sales.
    Thinks out loud
    Apr 2012
    "The Skillet" AKA..... La Quinta, Ca
    Exclamation
    And the beat goes on. Or should that be bandaids?
    One sure fire way to deminish years of heat complaints is to produce something worse. Done!
    Teddys favorite human
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Lightbulb
    Quote Originally Posted by Hayfield View Post
    No doubt, what you say has merrit, but think about it......... what would that really solve?
    You'd be forcing ambient air into the engine compartment only when your moving at higher speeds.
    I don't think most of us complain all that much about that issue in particular. (IMHO) The real problem seems to be when we're going slow or in stop & go traffic, & the heat builds up under the tupperware and when the radiator kicks on and causes the right foot to get torched The solution of the air scoop under the mirrors wouldn't really help much in these cases....... would it?
    Heat rises, and those vents were placed there in an effort to give the heat another route of escape, instead of being trapped under the tupperware. Many of the posts I've read about the Vertika air-scoops that owners have them installed are not all that glowing of an endorsement and the results seem marginal at best, again at least from what I've read. I've yet to see anyone post that it relieved their problems with the heat.
    Quote Originally Posted by MrLooney View Post
    Don't forget about FiberGlass & or Carbon Fiber (not that Carbon-fiber is cheap by any means) I do believe the parts that Vertika builds are actually made out of FiberGlass.
    Sep 2013
    Alberta, Canada
    Quote Originally Posted by CyncySpyder View Post
    with you Dave. Those top vents meant to let the hot air out by creating the negative pressure behind those clear plastic deflectors. There was a reason why BRP had them designed that way and I would not recommend changing it.
    Jul 2011
    Bay City, Michigan
    I worked with a buddy last year to remake the lobster "Y" piece on the gs/rs to put air inlets on the front. I actually have a prototype and ran it for a while on my GS but it seemed that it just trapped air in the top and the piece got really hot.
    Jun 2010
    Post We solved ALL our issues with heat but its not one that I can reccomend to non-DIY'rs
    Quote Originally Posted by Barlock View Post
    Oh but we did change it, tho exactly the opposite of the OP and added a small fan to the inside of the grill to help the hot air to escape, but we also added an 'on-demand' inline blower and removed the entire OEM Air-Box & resonator as well, so its a bit of an exteme make over but it works wonders and we also installed a digital temp gauge to show exactly what our 'under tupperware' temps are running and as soon as it starts heating up, flip the switch, and within 1 minute, its usually back to whatever the ambient temp is outside Problem solved, allthough as stated, not really an easy solution but it works for us
    ...in the pink (Girls On Spyders)
    May 2010
    Friendswood, Texas
    Better air flow might help to get rid of hot air....but a better solution is for BRP to come up with a flash for the ECM.....remove or re-position the CAT......get rid of the CANISTER....Carlo @ BRP....I'm waiting for your call...thanks Carlo...really appreciate the call...ball is rolling
    Thinks out loud
    Apr 2012
    Arrow
    [QUOTEBarlock;713191] with you Dave. Those top vents meant to let the hot air out by creating the negative pressure behind those clear plastic deflectors. There was a reason why BRP had them designed that way and I would not recommend changing it.[/QUOTE]
    The negative pressure concept goes out the window the moment positionable air deflectors are installed.
    Truth Is, none of us will know 'for sure' what will or will not work until there's extensive testing done. Unless someone gets lucky.
    Most are merely searching for a cure to something BRP obviously wants no part of, and, that's unfortunate for Lots of folks.
    Jm2c
    Jun 2013
    queens ny
    Default Here's what you do..!!
    remove the gargantuan air box, install kewl or similar system and mount a radiator fan facing downwards. Remove or perforate the engine plates at the bottom and add a manual/sensor switch. Now when slow or stopped you can turn the fan on drawing fresh air through the upper vents and blowing the accumulated air out. As they say back home "el papel aguanta todo" loosly translated it all works on paper....
    Jun 2013
    It seems like Spyder Pops has been successful with things like the "Missing Heat Shield"
    "You'd be forcing ambient air into the engine compartment only when your moving at higher speeds.
    " I don't know about your Spyder, but my seat gets very hot, even at highway speeds . . . I've received 1st degree burns where my legs touch the place where the seat ends and the heat comes out from under the seat. . . . .
    "Heat rises, and those vents were placed there in an effort to give the heat another route of escape, instead of being trapped under the tupperware." . . . Perhaps that was the intent, but it doesn't seem to be working, or else my master cylinder, brake cable, and charcoal canister would not have melted. A fan, in association with a ram vent would force incoming, cooler air, through the tupperware and out the bottom. JMHO
    May 2013
    Clinton Twp Michigan
    Quote Originally Posted by Jerbear View Post
    Jm2c[/QUOTE]
    I thought reports claimed that the movable vents still resulted in sucking out heat.
    Thinks out loud
    Apr 2012
    Arrow
    [/QUOTE]I thought reports claimed that the movable vents still resulted in sucking out heat.[/QUOTE]
    We are warm enough here to still have temps under the tupperware that range between 102/7 degrees. Pull a glove off and place your hand in the air flow on the drvers side of the vent, and there's major heat being vacumned out of the top vents. Wish it was not true. But, that's the result in my case.
    I think it's good that folks are kicking around lots of ideas...
    Somebody will hit upon a bit of magic; I have no doubt of that!
    Granted; it's a shame that they have to...
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default fact of life
    1. engines make heat.
    2. bikes have engines.
    3.engines make bikes hot.
    4. nature of the beast.
    5. fact of life.
    6.
    it was fun while it lasted.
    Jun 2013
    queens ny
    Default solution
    i will bet that brp will come up with a idea to allow more air into the engine compartment through side vents on the bike and also might come up with a way to put a fan under the body to come on at slow speeds to force air out the back of the bike to stop the hot seat issue. or they will just continue to say we are working on it until someone gets burnt bad and at that time they will come up with a fix very fast. but this is just me thinking out loud
    Mar 2012
    NJ
    Quote Originally Posted by coz View Post
    5. fact of life.
    6.
    Yup! Yup!
    Maybe just do a naked version of the Spyder!
    May 2011
    cincinnati, ohio
    Quote Originally Posted by DrewNJ View Post
    Yup! Yup!
    i like that, stainless mesh see- thru body panels, very sexy.
    May 2013
    I dunno, don't want a tryke that reminds everyone of Cher or Lady Gaga.
    May 2011
    cincinnati, ohio
    Default everybody
    could see your juggs.
    Jun 2013
    5. fact of life.
    6.
    Other facts of life . . . melting master cylinders, melting brake cables, melting charcoal canisters are not normal . . . there is an issue, here. If you don't have that problem with your Spyder, well, thats just great . . . good for you. However, to cavalierly discount the validity of the issues almost half of 2013 Spyder riders are experienceing, according to the survey someone else conducted here is fatuous . . . I've ridden since the 60's and never had this kind of problem, before.
    May 2011
    cincinnati, ohio
    Default spyders + heat
    i've been around here for a while now. since day one people have bitched about the heat coming off their spyder, it never ends. as for the 13 models, if you have a heat problem, take it to a COMPETENT dealer and get it fixed.
    Thinks out loud
    Apr 2012
    Question
    There are people here who have done exactly that. Some have traveled hundreds of miles to a great dealer, AND, are still reporting problems.
    What would you suggest they do?
    I'm sure they will hang on your every word.
